Question about Acer Aspire 3003WLCi Notebook
I have an acer aspire 3000 and there is a white single line going across the LCD, I put an external monitor on it and there was no line on the external one. Any help on this?
  • rjprice1 Mar 07, 2009
    I hooked up an external monitor and the line was gone when the os loaded to it, so that tells me the LCD is bad and not inverter or video chip.
  • 1,223 Answers
UR LCD IS DAMAGED first try to change the inverter cable inside the lcd if it helps then replace lcd if doesnt solve ur problem
pls rate me fixya if i solved ur problem
Posted on Mar 04, 2009
  • Shoaib Rais
    Shoaib Rais Mar 07, 2009
    yeah it is the case here u have to check the flex cable connecting the lcd to laptop may be it is damaged otherwise ur lcd is bad but first try the cable thing inside
    hope it helps
  • Shoaib Rais
    Shoaib Rais May 28, 2009
    I was trying to help and it is Free as u know i am not getting any
    financial gain from helping u, the only thing i need is good rating, so
    kindly update ur rating for the solution and more questions are welcome
Vertical gray lines
If you can obtain a desktop monitor used for PCs, plug it into the side port on the laptop. Start up the system and see if it runs OK on the external monitor. If so, the problem is with the LCD display on the laptop.
Feb 27, 2014 | Acer Aspire Computers & Internet
White horizontal lines running across laptop screen
I did not see any white lines, Simon, in the screenshot.
Just sayin'.
(Glad you tried to post it though!)
The problem is caused by a faulty Video Cable, or it's in the Display Assembly.
However, you better start the diagnoses with using an external VGA monitor, and see if the lines show up on the external monitor, also.
This would indicate a bad graphics chipset.
For most people that would mean replacing the motherboard.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA connector, on the Left side of the laptop.
Example of a VGA cable, and VGA port, (Connector),
You can use a external VGA monitor that is a CRT type, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
A1) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external monitor.
IF Not,
Press, and hold down on the Fn key, (Bottom left of Keyboard), and at the same time tap on the F5 key. (Top of Keyboard)
{The F5 key is the Display Toggle-Over key }
There are at least 3 display options available.
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY.
Hold the Fn key down again, and tap once more on the F5 key.
Graphics look good on external VGA monitor?
Your graphics chipset is good.
Problem is Video Cable, or in the Display Assembly.
B) Video Cable: (LVDS Cable)
The above is for an Acer Aspire 7751G, but it is close enough to the 7750G models, and info should directly crossover.
Scroll down to Step 17.
The Video Cable connection to the motherboard, is shown by the yellow arrow at the Top Left.
Note, although the photo is less than, the routing of the Video Cable.
It goes through the Left Hinge.
(Then into the Display Assembly, and connects to the back of the LCD screen)
With normal opening, and closing of the laptop, the Video Cable could be pinched, or have been pinched. Could have been pulled on.
You close the laptop, the cable is slightly pinched in the Hinge, and it pulls loose from the motherboard connection, AND/OR the LCD screen connection.
Doesn't take much of a loose connection. In fact it's hard to discern with the human eye, sometimes.
Make sure this motherboard connection is tight.
You have to open the Display Assembly, and check the Video Cable connection on the back of the LCD screen.
Doesn't look loose? Try to plug it in tighter anyway.
Check the connection of the wire/s from the Video Cable, TO the screen Inverter.
The small circuit board behind the Display Bezel, (LCD Bezel), and mounted to the bottom of the LCD screen.
When on the motherboard side, the side of the Video Cable that runs through the left Hinge, is there any apparent damage? Damage to the sheath of the Video Cable?
If there is, chances are the tiny wires inside the Video Cable, are damaged also.
Check with a multimeter. Perform a continuity test of Each wire.
C) Display Assembly:
Video Cable checks out then the problem is in the Display Assembly.
1) Screen Inverter:,Aspire-7700-thru-9800,Laptop,Inverters.aspx
Not your model, granted. Posted for the Display Assembly dis-assembly pictorial guide.
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL, or a series of LED lights.
Your laptop uses a series of LED lights for the Backlight.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A CCFL requires a screen Inverter.
A screen Inverter converts the power from the laptop, for the Backlight, and LCD screen.
NOT all LCD screens that use LED lights as a Backlight, use a screen Inverter. I suspect yours does not, as I can't find a listing for a screen Inverter, for it.
This would mean that if the Video Cable proves to be good, the next step is to replace the LCD screen.
Shop around for the best price, AND make sure it is a direct replacement for yours.
Feb 12, 2012 | Dell Inspiron Computers & Internet
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
How to connect external monitor to aspire 3000
plug in the new monitor to the notebook, then right click background and then click properties. Then go to the settings tab, at the bottom of that click advanced. Next Click monitor. There you should see the external monitor for you can set the display to this one.
Oct 25, 2011 | Acer Aspire 3000 Notebook
Acer 5515 on external monitor
Get an VGA cable and connect your external monitor to your laptop via a VGA port that is usually used for digital projectors. In this VGA port, you can initiate dual monitors.
Then look at your keyboard and look an icon in your function keys (F1 to F12) that looks like a pair of an LCD and a TV like this {LCD icon/ TV icon}. In most laptop keyboards, this is located in F4.
When found, and with the external monitor hooked to the laptop via VGA port using a VGA cable, press and hold down the FN key and press the function key where the icons described above is located. Example, FN + F4 to toggle a single and a dual monitor.
Give it a try.
Jun 26, 2010 | Computers & Internet
Aspire 3610 have a vertical line on its screen why?
3 options:
1.) LCD faulty
2.) Mainboard faulty
3.) LCD cable faulty
Please reseat LCD cable components and recheck. If it gets worse or less, then you know the LCD cable is faulty.
Please test on external monitor. If line is gone, and above is not true, then your LCD is faulty
If Above is false, and line continues on external monitor, then mainboard is faulty.
Jun 01, 2010 | Acer Aspire 3680 Notebook
Acer Aspire 5585 Laptop LCD Problem
You need to replace the inverter of your lcd screen.
Oct 02, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Aug 24, 2008 | Acer Aspire 4315 Notebook
Most latop are on board video rather than a seperate card.
If the external adapter is working with an lcd screen then it must the laptop screen that is faulty and not the video card/ on board gpu.
Jan 08, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3003WLCi Notebook Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
