Question about HP Color LaserJet 2600n Printer
Problem with my HP Printer 2600n
It is showing 'Paper jam in output bin' I have opened the door and checked and it is fine. I've turned it on and off and it still appears. Any ideas?
Thanks John
  • 530 Answers
Hi im josh in cebu phils.may i help you? Friend this possible solutions of mine:
Problem: Paper Jams in Your Printer It's possible that your printer's internal paper feed mechanisms are getting dirty. You can try taking the printer apart yourself to clean out any pieces of scrap paper or other debris, or you might want to take it into the shop to let a pro deal with it.
You might also be getting some paper sticking to other sheets of paper in your paper tray. (This happens more often with cheaper paper—spend a little more and get the good stuff!) Try thumbing through the stack of paper before inserting it into the tray; this should loosen up the paper and make it feed easier into your printer.
Finally, you might need to change the grade of paper you use with your laser or inkjet printer. Lightweight papers tend to jam up the works, so switch to something heavier if you experience a lot of problems. thats all friend good luck
Posted on Mar 04, 2009
  • Joseph Baculan
    Joseph Baculan Mar 04, 2009
    hi im josh in cebu phils.may i help you? Friend this possible solutions of mine:
Can't find paper jam in output bin
Jamn output bin". When I open the door, and clear the jammed paper, it still show the problem.
Jan 25, 2012 | HP P2055DN LaserJet Monochrome Printer
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
Can't find the paper that is jammed in the printer (laserjet 2600n) its says its in the output bin
The output bin sensor check the quantity of printed paper that remain in the upper part of the printer. When the paper is too much, the sensor report a paper jam.
Check the lever of the sensor in output bin if it's working properly
Jun 15, 2011 | HP Color LaserJet 2600n Printer
Paper Jam at HP LaserJet P2055d
There is output sensor where the papers come out, make sure its lowered down, be VERY CAREFUL not to break it.
Jun 11, 2010 | HP LaserJet P2055d Printer
My printer says there is a jam in the output bin but there is no visable jam. HP color laserjet 2600n
Just try the steps
Jam in output bin - fuser area Error messageJam in output binalternates withOpen door and clear jam DescriptionA paper jam has occurred in the output bin near the fuser area. Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.
Jam in output bin - duplex area Error messageJam in output binalternates withOpen door and clear jam DescriptionPaper jam in duplex reversing area Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Jan 28, 2010 | HP Color LaserJet 2600n Printer
Jam in bin
this is a common fault. look where the paper was jammed, you may need a torch. There is a black or white sensor there that has been dislodged. Once clipped back into place it will then report to the printer that the paper path is clear and no longer a jam.
Oct 05, 2009 | HP Color LaserJet 2600n Printer
How to clear paper jam in output bin
The printed page comes through the hot fuser at the top of the printer, through the exit rollers an end up in the exit bin.
We cleared a massive paper jam out of the fuser, by removing the grey surround on top of the printer. The plastic hooks that hold it in place get broken in the process, then you will the jammed paper between the fuser rollers, and the exit rollers. A technician can do it for you, but is unessersarly costly.
Dec 21, 2008 | HP Color LaserJet 2600n Printer
2600N Printer has an output paper jam
open the back cover you will see a blue knob , just turn it ,jamming paper will coming out
Dec 08, 2008 | HP Color LaserJet 2600n Printer
Paper jam
That part is the fuser unit and is hot if the printer is on. Here are instructions for you. Good Luck!
http://www.laserpros.com/pdf/HP%202600-2605%20fuser-etb.pdf
Jul 27, 2008 | HP Color LaserJet 2600n Printer
Jam in output bin
Make absolutely sure there actually is no paper jammed in there.
I came to this page with the same warning, convinced I had a software glitch. Turned out there was a page accordion-folded down to the size of a pencil lead. I didn't know paper could be folded that small.
Of course, everyone here may be a lot brighter than I am, in which case sorry to waste your time. But for me, the obvious first fix needed to be thoroughly explored before cursing HP and their machine.
Jul 08, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
342 people viewed this question
Seeker5211
Seeker5211
