Question about Sony VPL CS5 Multimedia Projector
Sony VPL-CS5 menu will not display
When I switch on my Sony VPL-CS5 the lamp turns on and everything appears normal, but pressing the Menu button will not display the menu. Pressing the Input button shows nothing either. All that is being display is a bright white light like the projector is a rectangular torch.
Please could someone advise what is wrong?
  • 115 Answers
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Posted on Mar 04, 2009
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    How to reset the lamp timer for Sony Projector vpl-px32
      Instructions
        • 1 Turn on your Sony projector after replacing the lamp.
        • 2 Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
      • 3 Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
    Jul 07, 2014 | Panasonic PT-44LCX65 Television
    How do you reset the lamp timer for a sony Bravia
    Turn on the projector
    press MENU (as show in picture step by step)
    use down arrow key and select SETUP
    press ENTER
    use down arrow key to select LAMP SETTING
    press ENTER
    menu screen below will be appeared.
    ON SCREEN display
    setting for lamp replacement
    Has the projection lamp been replaced?
    YES NO
    Select YES with left arrow key (yes is preselected)
    press ENTER
    ON SCREEN display
    lamp replacement process is now complete
    press ENTER
    now exit the MENU with menu key and check the lamp timer
    Feb 09, 2011 | Sony BRAVIA VPL-AW15 LCD Projector
    I just replace a lamp on Sony vpl-cs20 and lamp timer is still high
    You should turn on the VP-CS20 with the button on projector, NOT THE REMOTE or the instructions wont work.
    Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
    and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
    Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
    to the customer setup menu. Press the "MENU" button to view.
    Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
    "RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to zero in the service menu.
    Hope it helps,
    FVazquez
    Sep 22, 2010 | Sony VPL-CS20 Multimedia Projector
    How do I reset the lamp timer on the Sony VPL-DS100?
    Yes, press RESET, <, >, ENTER keys on remote simultaneously to reset lamp timer. Display of lamp will also change to zero.
    Make sure projector is just plugged in and should not power On (in standby mode) to reset lamp timer.
    Jun 03, 2010 | Sony VPL-DS100 Multimedia Projector
    DIRTY LAMP FOR VPL-CS5 SONY PROJECTOR (USED)
    to clean the lamp: no chemicals, nothing abrasive. you can touch the outer glass (not with your fingers), but do not touch anythjing inside the bell. best thing to use is a microfiber cloth. your lamp is nearing or has passed 2000 hours of use. the projector is telling you to replace it before it blows (and sometimes shatters). after you replace it, reset the lamp timer (through the menu).
    Dec 17, 2009 | Sony VPL CS5 Multimedia Projector
    Sony VPL CS5
    You need to clean the filter , the unit is shutting down so it doesnt over heat..look for online manual on how to remove filter and blow off dust.. Good Luck
    Jun 30, 2008 | Sony VPL CS5 Multimedia Projector
    Lamp change
    You have to go to the settings on the projector and reset the lamp timer.. Go to your on screen menu and go to settings.. Good Luck
    Mar 05, 2008 | Sony VPL CS5 Multimedia Projector
    Sony CS5 Wont turn on
    the cover switch is probably not fully made.
    Ensure that the cover tangs are pushing the pin
    on the miniswitches.
    Try putting slight pressure on the fan or lamp cover to see if the lamp/cover light
    stops flashing.
    you will need to do a restart on the PJ to check this out
    Jan 15, 2008 | Sony VPL CS5 Multimedia Projector
    Sony VPL CS5 Multimedia Projector Logo
    385 people viewed this question
    Top Sony Office Equipment & Supplies Experts
    shaun taylor
    Jaime Hernandez
    Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
