Question about Microwave Ovens
Need whirpool model ukm 137 230v-240v hub that rotates the glass plate.Mitchell phone no 0141 556 2805 Norm.mitch1@btinternet.com
  • Microwave Ovens Master
  • 9,086 Answers
You can find Whirlpool UK spares / parts here.
Posted on Mar 06, 2009
Where can I get a glass turntable
Are you talking about just a new glass plate for your specific oven or a generic turntable mechanism? If just a glass plate, you have provided no brand or model info. Just examine how your old plate engaged - they aren't all the same but some will interchange. There are also inexpensive turntable devices that can be used to retrofit ovens without a rotating mechanism.
Sep 09, 2014 | Microwave Ovens
Center will not rotate
The glass plate is driven by a motor underneath. Power may not be getting to the motor or the motor may have failed
Jan 17, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
The removable small circular item that causes the glass plate inside the microwave to rotate is broken. How can I get a replacement. The model # is JVM1631BB007
Appliancepartspros.com $15.72 Part#AP3410753 You just put in model # and your micro will pop up. Part 84 on diagram location.
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turntable is jerky rather than smoothly turning... it's a Whirlpool Gold GH8155XMB-0, made in October 2003 ... is there some sort of belt that can be replaced or motor or something? Otherwise,...
first check the roller under the turntable is correctly seated if so pull the drive coupling out from inside the oven and check for damage. If all of the above are OK you will need a replacenet turntable motor
Dec 28, 2009 | Whirlpool MH7140XF Microwave Oven
How do you turn the carousel on/off on a Kenmore Microwave Oven model: 5658932580
Look at the owner's manual of similar Kenmore models there does not seem to be a setting that allows you to turn off the turntable. However if your microwave (sorry but I couldn't find your exact model number online) has the time of carousel that has a lift out glass plate with a notch (hub) in the center of the bottom side then you effectively turn of the carousel my removing this glass plate. (see pg 4 of the manual - above link) You can place a normal microwave safe plate in the microwave in it's place. Make sure to leave the rollers in place...just remove the turntable.
Nov 08, 2009 | Microwave Ovens
Glass plate does not rotate
on the bottom of the micro underneath the shield there is a small moter for turning the plate.. also if the plate and roller are not centerd correctly it will not turn ,.. remove the plate and balence a glass on the triangle in the center of the micro shut door and start micro observe if turning ..also some micros have a button selection on the control to reverse the micro plate rotation and stop it --check these things and get back to me..
Aug 10, 2009 | Microwave Ovens
Need to replace Panasonic NE8070 model, 15in dia,microwave plate
hi my name is mark, i found panasonics part website follow link http://www.pstc.panasonic.com/Epartr/PartsListChoice.asp?validate=1 if this helps please rate how i did. thanks for you question.
Mar 18, 2009 | Microwave Ovens
Plate does not rotate freely and make noice
There is no belt in your model - the turntable is motor driven. The problem is either the motor itself or the coupling that engages the glass tray.
The motor (GE part # WB26X10038) is a very common failure as the internal gears are plastic and tend to strip.
You can view the motor at this link...
www.microwaveglasstrays.com
Jul 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
90 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
