Question about Kitchen Ranges
Thermostat needs replacing in Zoppas Electrical Cooking Range Class 21 Model 21 645 but cannot find a replacement Thermostat. Can you suggest where I might find one, please ? Billy Gardiner
  • 19,396 Answers
Hi Bill , you can try partstselect.
I can be more specific if you tell me your location and the model number of your appliance.
Posted on Mar 04, 2009
Why do I get E 21 message on my Electrolux slide in range Model EW301S6CjSc which has frozen the stove top
Thank you for your post, Sandra Gee!
Based off the information you have provided an "E21" error code is displaying on your Electrolux range. Typically, an "E21" stands for a communication failure between the EOC (Electronic Oven Control) and the ESEC (Electronic Surface Element Control). I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. The best way to disconnect power is to flip the household circuit breaker. If you continue to have an issue with an "E21" error code I would have a professional technician perform a diagnosis on your range to help repair it properly. Hope this is helpful. -Matt
Dec 25, 2014 | Electrolux Kitchen Ranges
Ge hood insert zvc36l1ss fan comes on by itself. When not cooking?
The switch is bad. That makes it a possible fire or electrical hazard.
You should replace the switch immediately, or at least turn off the breaker that supplies power to the unit.
Don't let a broken $20 part be responsible for burning your home to the ground, fix it!
Parts for this hood are at http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Range-hood-Parts/Model-ZVC36L1SS/0432/0122400
This shows you how to open it up and replace the parts: http://www.searspartsdirect.com/partsdirect/user-manuals/9235/ZVC36L1SS-GE-Parts-RANGE+HOOD-manual?pathRender=fromManualTabPage
Jul 26, 2014 | Microwave Ovens
How to remove thermostat on PLEF398C
Hello Edward, thank you for your post!
Remember, these intricate part replacements do require precision and patience, therefore when replacing parts that require the exchange of electrical wiring harness or removing your range, I always suggest seeking professional advice. One must be very careful as these replacements can lead to any potential harm.
Best regards!
Dec 29, 2013 | Frigidaire FEF336BC Electric Kitchen Range
KESA907pssoo, put in clean mode all went black. no power, door is locked can't get front panel off as held in place by thin vent duct. Solutions?
Hello, welcome to FixYa.
It sounds like the hi-limit safety thermostat may be tripped, that is the component that typically trips/activates during a self clean on many ranges. You shouldn't need to open the front control panel, but access is through the back.
You'll need to slide the range/oven outfrom the cabinet. If you slide the unit away from the wall and unplug it you can replace the hi-limit. It will be a non-reset type hi-limit (based on the model number you posted) so needs to be replaced as I mentioned, doing so will get you back up and cooking in no time.
**Unplug the range from the wall first of course...safety first**
Once you remove the panel you will need to look for a switch/thermostat which looks like this...
The replacement according to the model number posted is 9759242 and available at "searspartsdirect.com" or "repairclinic.com" to name a couple.
Let me know how you make out. Good luck. I'll watch for your reply and if you need anything further I'll be glad to help in any manner I can.
Regards,
Macmarkus :)
Aug 14, 2011 | KitchenAid KESA907P Electric Kitchen Range
My oven will not stay at desired temp. It gets much hotter than the desired cooking temp. could this be a thermostat problem?
The thermostat is designed to regulate the desired temperature. If it is getting far too hot then the thermostat requires replacement.
Feb 10, 2011 | Frigidaire FEF366 Electric Kitchen Range
I have a Chef Ceran Cooktop Model EHC64oU with four elements. The problem is that it doesn't seem to cook anything on a low heat. It stays on low for a few minutes and then the the temperature increases...
I am assuming having looked up the model that you have a glass top range. These ranges use a thermostat to regulate cooking temperature, and when they go bad you will either suffer from erratic cooking temperature or have no heat at all. The best solution I can think of is to replace that thermostat.
Aug 05, 2010 | Cooktops
FDD8 sandwich maker will not heat up
The purpose of the button is to shut off the power to the heating coil when there is no cooking plate in place. It appears by your tests that the button (switch) has failed. You can jumper around the switch to verify that this is the case. If the heating coil gets hot with the jumper in place, then you need to replace the switch (button). If it does not get hot, then either the heating coil has a bad connection to the wiring. the coil is actually bad and needs to be replaced or there is a break in the neutral circuit somewhere. Did you do a continuity check on the neutral side of the circuit? There should also be a thermostat (tempurature control) and a thermofuse in the circuit that you should also check for continuity.
Mar 10, 2009 | Krups FDD813 Meal Master Sandwich / Waffle...
Last night we were cooking on our Whirlpool Electric Range, Model #RF366PXDN. Sparks and smoke shot out from the burner knob. What might be the source of trouble & how might we repair the problem without...
you have a short in the electrical and i suggest you call a service repairman to have it looked at but he will probably tell you to get a new stove,,,there is no simple solution to this
Jan 01, 2009 | Equipex PZ-330 Electric Single Oven
RIVAL Crock Pot 3350 - Replacement of Cooking Pot
same, it was given to me as a gift from my aunt a very long time ago, just last night the liner broke. Where can i go to find a replacement liner?
Mar 05, 2008 | Rival 33511 5-Quart
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
