Question about Dell - NPS-200PB-73M (NPS200PB73M) Power Supply
Computer won't turn on
I have an Alienware PC with the full water cooling etc. When I switched it off last night I noticed that it was making a funny repetative pulse type noise so I switched off the power suply. When I came to switch it on this morning it wouldn't start it made the noise for a little while then nothing.
    President:
  • 1,223 Answers
RAM faulty try reseating it or replace the ram an check
clarify ur problem more if not solved yet
pls rate me fixya if i solved ur problem
Posted on Mar 04, 2009
My Alienware M9700 starts up but turns off before Windows can start
sounds like a thermal shut down maybe heat sink is full of dust under cpu fan or you need fresh thermal paste on processer
Jan 03, 2014 | Alienware PC Systems Alienware Aurora High...
Alienware power button
it is possible the power switch behind the button has slid out of position. The power button on the machine is usually more of a "pretty face" to press the switch behind it. I would take off the front cover of the PC (be careful not to break any tabs etc, they are usually plastic and easily breakable) and then try pressing just the little switch directly behind the power button on the front panel....if this works every time, you may need to push it forward from the rear a little bit so that the power button on the case's faceplate is making solid contact with the switch.
Feb 25, 2013 | Alienware PC Systems Alienware m15x Gaming...
Desktop won't make a sound when I turn it on
Check to make sure the power switch on your surge protector hasn't been reset - also check the connection at the back of the computer -
Jan 15, 2013 | Systemax Venture PC Desktop
Alienware Area-51 Desktop won't boot up long beep
The fan to the left of your RAM slots needs to spin, it may be the reason for your problem. If this is the CPU fan then you may have a dead CPU.
Contact a computer technician for repair or claim warranty support.
Take care!
damnor01
Sep 21, 2012 | Alienware PC Systems Alienware Area-51®...
Hit start Alienware computer goest to alien head on screen then straight to sleep mode. Please read
When you say computer clock do you mean the LED read out on the mother board? if so the numbers you are seeing are error codes you will need the mother board manual to know what those codes mean. If you don't have the manual it's possible you can go to the mother board manufacturers web site and download one then you can look up the codes to see what the problems are. Hope this helps
Jul 26, 2012 | Alienware PC Systems Computers & Internet
ALIENWARE DESKTOP LOST ALL POWER
In a laptop, you can lose power in three ways.
1. Dead battery 2. Dead Power cord. 3. Bad motherboard.
ther first two should be rather obvious, as the battery won't work or it won't hold a charge, but if it won't turn on at all, even while plugged in, chances are that you're going to need a new motheboard. This can be expensive in the M--x laptops, unfortunately.
Sorry for the bad news, mate.
Apr 29, 2011 | Dell Alienware M11x Gaming Laptop Computer...
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
If on a xp desktop the option for the power switch to do nothing is selected and then the unit is shutdown ... :o( how do I get the computer to turn on now. can not turn power on to use any cd. how do...
When That option is selected it does not effect how your computer turns on so the problem must be unrelated to that. I think you may have a hardware problem and will need to be fixed at an I.T store.
Apr 27, 2009 | Alienware PC Systems Alienware Aurora High...
Computers & Internet Logo
171 people viewed this question
Alun Cox
