Question about Westinghouse Dishwashers
Motor starts but no water entering dishwasher
Westinghouse Virtuoso sensorwash Dishwasher-Model SB925SJ*00When i push start button the Prewash and Heavy buttons are lit and 116 (minutes)on LCD panel-There is a quiet motor sound like as if it is going to fill but no water enters the machine,after i minute the motor stops and Prewash light is flashing as it counts from 116 down to 114 then the following all light up and motor starts & still no water- Prewash,Wash,Rinse,Fandry-all lit up.Then motor stops and it starts beeping and it shows a 10 in theLCD panel.Thanks Michele
  • 3 Answers
TRy priming by putting a jug of water in bottom of inside of dishwasher
Posted on May 15, 2009
  • Michael
    Michael Apr 25, 2014
    Same problem as above but different model SB922SH#01 have tried priming works but you shouldn't have to prime it every time you use the dishwasher have any ideas thanks?
When I push the start button water does not run into my dishwasher
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 31, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher soap still in door after wash cycle, so dishes are not very clean. Soap dispenser cover is sprung open but soap (on both sides, wash and prewash) is still mostly where it was poured, only now...
Check for the right amount of water in tub. In this unit close to the lip of the tub after fill. If water fill is correct check movement of lower spray arm. Other possibilities delayed action of dispenser from defective wax motor. Most probable is wash motor. Start unit after fill and when was starts, open door and see if water is being pushed to the top rack and dripping from the top of tub. Motor is easy to install.
Oct 12, 2010 | Maytag MDB7100AWB Dishwasher
No heatinh - Westinghouse SB925SJ*00 - suspect dual water sensor (Water presence and temperature). Require price and availability. Thanks.
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2010 | Westinghouse Dishwashers
Whirlpool dishwasher stuck on prewash cycle
the eprom memory is brocken,the main board must be changed.
Feb 14, 2010 | Whirlpool 24 in. ADG7952 Built-in...
Dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
May 30, 2009 | Westinghouse 24 in. MDB421 RF Built-in...
No solution as yet, will most likely replace the dishwasher.
May 31, 2008 | Westinghouse 24 in. MDB421 RF Built-in...
Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Jun 13, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Start flashes and will not begin wash cycle
My dishwasher Model is 665 15891790 and the serie #FG3907905. After programing my dishwasher and pressing the start button, it fills with water, but when it is due to start the sensing light comes on. I have notice that the ring under the watering arm on the bottom of the machine seams to be cracked. Could that be the problem for the machine not starting its' cycle. Thank you.
Jul 01, 2006 | Kenmore 24 in. 16293 Built-in Dishwasher
Dishwashers Logo
640 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
