Question about Neff 24 in. S5443X2 Built-in Dishwasher
Modell S5443X1GB water not pumping out,no
Modell S5443X1GB water not pumping out,no blockages,pump not obstructed,seems to be programmer problem?any ideas
  • Neff Master
  • 19,396 Answers
First you need to ensure that the drain pump is working.
The drain pump is tested by the technician by energizing the pump directly, so to understand if the pump solenoid is working.
This is an unsafe job for the home user, as there is AC inside your appliance, all live power test should be done by techs.
Apart testing the pump, check also the wiring harness to the pump.
If the pump is fine, then replace the control panel.
Here you find parts for your appliance and repair help.
Posted on Mar 04, 2009
Neff s5443x1GB/29 dishwasher starts and stops
The pressure chamber or hose (pressure chamber to sump) may be blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 16, 2013 | Neff Dishwashers
How to open machine to get at pump of model gw709au machine will not empty water any ideas
Drain pump located underneath. Disconnect from power.  Bucket out as much water as you can, then lean machine over backwards so you can see underneath. The drain pump is located front right of machine- you will see a fan blade, this is the drain pump. The fan blade should spin freely if you turn it- if not, you have a blockage in pump. To remove pump: disconnect wiring plug connection + earth wire. At the top of pump there is a white plastic tag- lift up and turn pump anti-clockwise to remove. Note- water will come out when you remove pump, so put down some towels!!. Now, with pump removed, feel up in hole where pump came from for blockage and remove obstruction. Reverse procedure for reassembly, and test. If still not draining, blockage may be further up system, requiring removal of inner bowl to clear (not recommended for DIYer- call in the experts!!). Good luck!!
Mar 10, 2010 | Fisher and Paykel Washing Machines
I have a Hotpoint wma48 and it will not drain the water. It is full of water and none of the programmes will now work, any ideas what might be the cause?
Probably a blocked filter.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here.
This should solve the problem.
Dec 14, 2009 | Hotpoint WMA48 Front Load Washer
Whirlpool lsr 8233eqo runs over every time any help out there
The main things that will affect time on any programme are the flow rate of water coming in, flow rate of water being pumped out and the temperature of the water coming in and the amount of heating required to be able to run the chosen programme. If the water is colder coming in then it takes longer to heat up and hence the programme takes longer than expected. If there is any blockage in the outlet pipe or blockage in the filter or pump it takes longer to pump out the water at each cycle and therefore the programme takes longer.
Nov 17, 2009 | Whirlpool Washing Machines
Im getting f -05error towards the end of all programmes and cant get it to spin or pump out on a hotpoint aquarius wmf50
F05 means that the pressure/\water level switch is jammed on full.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove other end of hose onto pump, and check for blockage or obstruction here.
Please rate my solution.
Thanks.
Nov 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I have a two cylinder volvo penta saildrive 2002 model, their seems to be little or no water coming from the exhaust when the motor is running. i have recently antifouler the leg and cleared the water...
Check your impeller in the seawater pump ( at the front of the engine )
If the impeller blades stays even lightly bent after removal, change the impeller.
Check for obstructions in the hoses.
Remove the water hose going to the exhaust.
Run the engine, if here you have a good water flow ( more than at the exhaust itself ) the the exhaust mixer is obstructed. Try to clean out with HCl acid. USE ACID resistand GLOVES. Rince twice as well after the obstruction is gone...
Nov 01, 2009 | 2002 Volvo S60
OE displays and washer will not drain
you have to check the pump,remove the hoses from the pump first and check for any blockage could be lint or a sock,if there is no blockage and the pump spins its the propellar for the pump is worn and you have to replace the pump
Jul 08, 2008 | Washing Machines
Hoypoint WMA58 won't empty
As you have probably found out, hotpoint washing machines do not have any customer accessible pump filters...
If you want to get on and fix this yourself you will need to get machine out and tip it up. have a look underneath. You will need tools etc.
1. Firstly check the power is off / disconnected.
**Next double check the power is off / disconnected.**
2. Check for obstructions inside the sump hose leading to the water pump. These machines have a filter/flap located in the sump hose which can get jammed up. See link http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=636775&brand=&model=WMA58&part=sump
3. My bet is that the pump itself is faulty. Check visually for blockages inside it - (do not dismantly)
For a replacement see the following for info on the pump. http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=640428&brand=&model=WMA58&part=pump
4. Finally I have heard of hotpoint wma's failing to pump water because the heater element is faulty -because water temp never reaches correct heat so programme halts.- but I cannot confirm this. To prove this put your machine on Final Spin - the first thing it does is empty the machine - no heating...
if it does then its probably the heater.
Regards
And don't forget to rate; thanks!
Feb 27, 2008 | Hotpoint WMA58 Front Load Washer
Hoover nextra 1200
The machine only allows a limited time for all the water to drain out before it starts spinning. If the is a blockage or obstruction in the drain hose or drain pump, the machine will not allow all the water to be pumped out and it will not spin. Check for any restriction especially under the sink/tub where the drain hose attatches to the drain spigot.
Nov 01, 2007 | Washing Machines
Neff 24 in. S5443X2 Built-in Dishwasher Logo
569 people viewed this question
Top Neff Dishwashers Experts
shaun taylor
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
