Question about Epson Stylus C46 InkJet Printer
Printer is showing "service required"
Can I solve this myself
  • Anonymous Mar 04, 2009
    i have a red and green light flashing alternatly, it says some of its products are comming to the end of their life?
  • 118 Answers
Try to reset it. you can download the apropriate print reseter here
Posted on Mar 04, 2009
SOURCE: c44ux problem
Most likely the ink pads need changing or you can take them out and give them a good wash and drip dry
Posted on Sep 30, 2008
  • 8 Answers
SOURCE: MY PRINTER SHOWS SERVICE REQUIRED
Try to re-insert the cartridge. And see if there is any paper jam inside the printer. If your printer cartridge is bit old try to replace it.
Posted on Mar 24, 2009
gwbm
  • 353 Answers
SOURCE: epson c62 printer say's parts need replacing, service required
These symptoms usually mean the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C62), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Posted on Apr 14, 2009
halbrook
  • 560 Answers
SOURCE: my epson r 230 printer is showing 'service require...
Epson programmed their printer to monitor the waste ink counter and your printer has reached the maximum value allowed, you have to reset your printer to clear the waste ink counter.
You may read the information regarding "end of life" and "waste ink counter" here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
To reset the counter, download re-setter program here, install and follow the instruction in the web site.
Good luck and thank you for using FixYa.
Posted on Jun 13, 2010
elix0411
  • 3530 Answers
SOURCE: mp460 shows notice "service required'
Welcome to Fixya
Try to reset the printer by following the procedurte below.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Thank you for using Fixya!
Posted on Dec 05, 2010
Printer Epson Photo R230 Service Required Error how to solve service required
If you are facing problem with your Epson Printer Photo R230 and required information about how to fix that justdial EPSON Printer Support Toll Free 1 888 924 2961.
Mar 01, 2015 | Epson STYLUS R230 InkJet Photo Printer
My epson r230 is paper jam..and log sound how i fix it
my problem is screen show service required please helpe me my solve problem,
Sep 16, 2013 | Epson STYLUS R230 InkJet Photo Printer
Epson L100 printer shows service required
how to solve provlem epson l100 printer's
Sep 18, 2012 | Office Equipment & Supplies
My printer canon mp258 show error 6000, how can I solve it?
You will need to reset your printer and this printer requires a software resetter fo many of its error codes. The newest and best available resetter with full instructions is available here.
Just follow the easy instructions and download their service tool and this should reset any error codes or problems you are having with the printer.
Hope this solves your issue.
Feb 20, 2011 | Canon Office Equipment & Supplies
Error 511 service required
You can try to clean the small silver square on the edge of the transfer belt and the sensor that looks at it, but usually it will require a new PCU to solve the issue. it is bettre if you show it to service centre.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | Epson Aculaser C1100 Printer
SERVICE CALL 7-71h
I'm sure you have tried unplugging the machine?
It's a scanner error. Is the scanner lock engaged? this would cause the problem.
Otherwise, it is more likely an electronic problem -either FCU or FCE -neither of which you are going to solve yourself.
Apr 10, 2009 | Office Equipment & Supplies
C44ux problem
Sep 24, 2008 | Epson Stylus C44UX InkJet Printer
Service error 5100. Cancel printing and Press OK button. If this doesn't clear the error, see the printer manual for more detail.
Had a same problem, here is what i ve received from canon support:
"Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
Please be advised that error 5100 indicates a carriage error and the machine will require service."
However I managed to solve it by myself by perform few paper path tests as there was a paper jam inside.
Nov 20, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Epson Stylus C46 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
