Question about Rinnai RHFE-556FAIII 21,500 BTU Ductless Energy Saver Heater - LP(Propane) Gas
Rinnai heater turns itself off
Hi. I have a Rinnai Energy saver 551f heater that won't stay on. I've pulled the back off and vaccumed out all the dust. I turn the knob to on and wait the 10 secs and the gas lights and then it turns itself off again. It didn't come with instructions when I moved in. Please help
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Dannizen,
You could have something as simple as an air hose off, or a piece of carbon on the flame sensor. Your problem could also be a gas valve , which is much more complicated. If you are handy with tools you could be able fix either quickly. If you’re not good with tools you will need to get some help. Either way you have to have some back ground info on your heater. Get in touch with Rinnai and get a service manual for your unit. They cost around $15. If you have to call a service guy, use the Rinnai web site to find an authorized service person. Don’t just let your fingers do the walking and get some guy who has no idea what a Rinnai is. You’re only asking for trouble there. Your unit is a little older so don’t be surprised if parts are hard to find.
Good luck,
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Posted on Mar 07, 2009
  • Rob9k Dec 01, 2010
    I had the same continuing problem with 2 Rennai ventless heaters. I solved it by vacuuming out the dust and webs annually but that only worked on one unit this time. The other would stay lit for about 2 minutes, then the heat and pilot would turn off. Here's where I found a lasting solution:http://www.foreverhotwater.com/documents... On page 6 there's an illustration for cleaning the oxygen depletion sensor. Without disassembling the unit as shown, I just blew compressed air, angled to the left, through point #2. Problem solved - for a few more years I hope.
    Rob
    New Friend:
I had the same issue and and I applied high pressure air from out side and it fixed.
Posted on Jul 16, 2017
Rinnai energysaver 551 ft starts but won't stay running
Those water heaters are very sensitive to flow rates. The service manual appears to be here: http://rdjxmmyvbu.blogcu.com/rinnai-551f-service-manual/13623970
But there is no guarantees
Jul 24, 2016 | Rinnai Heating & Cooling
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
Nov 26, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a rinnai energy saver 556f our power blew out and it knocked out all our appliances.i am trying to get my rinnai to stay lite but the pilot wont stay on.it goes on for about 3 seconds and then cuts...
Patrick,
Your 556 does not have a pilot light. When you try to start look into the window, you should see an arcing, this is the igniter. With a power outage there is no telling what may have happened. With only limited knowledge of a gas heater you should call a Rinnai service guy.
Good luck,
Tom
Oct 12, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Can you vent the Rinnai 551F vertically through ceiling?
This unit can be vented through the roof but requires a specialized flue system-do not use an existing flue connection. Call a contractor - have them check and see if the unit can be modified to a vertical flue- it will require the existing piping to be replaced--Not a job for a do-it yourselfer
Nov 01, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Heater 557ft won't stay on!
it sounds like a thermal cut-out switch. check that vents aren't covered?
Jun 01, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rennai 551 FA-P Never fully shuts off
Hebert,
Is there a chance there is a draft around the room temp probe? It is down low on the right side of the heater. If there is a draft the room sensor is fooled and keeps running the unit. You should be able to prove the room sensor by putting your hand over it after the stove has been running for a while. This should shut the stove down. If not there is a problem with the room sensor.
Tom Hawkins
hawkins111@gci.net
Jan 25, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Users manual for a rinnai 551f heater
Here is the owner manual : Rinnai wp
And here also an extra, the service repair manual:
Untitled
With compliments.
Nov 30, 2008 | Rinnai Heating & Cooling
Heating & Cooling Logo
3,861 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
