Question about Texas Instruments TI-83 Plus Silver Edition Calculator
Graphing calculator got coffee spilled on it
How do I get it to function? I changed batteries and still it doesn't turn on. I know when I had a problem with my cartridge video game system I was told to rub an eraser on the metal contacts. Should I open my calculator and rub it's metal contacts when an eraser? The calculator is a TI-84 Plus Sliver Edition
Thank you.
  • 29 Answers
Your only hope is to open the case and wash out all the coffee with plain water. Don't forget to clean all the keys and switches under them. Dry and reassemble. This is a last chance procedure and may fail.
Don't spill liquids on electronic gadgets as the result is either much work or must replace.
Posted on Mar 04, 2009
When graphing in documents my TI nspire cas cx is stuck in relation mode instead of function. How do I reset this?
How about starting a new document, or adding a new page, or just turning the machine off without saving?
Sep 24, 2016 | Texas Instruments TI-Nspire CX CAS...
Can not reset calculator. Keep getting + sign when press enter
If the TI-84 does not function even though you are sure that the
batteries are fresh, you can try manually resetting it by following steps:
1. Remove all of the AAA batteries from the graphing handheld
2. Press and hold the ON key for ten seconds
3. Replace the batteries
4. Turn on the unit
When you reset your graphing handheld, the contrast sometimes
changes. If the screen is faded or blank, adjust the contrast by
pressing 2nd and releasing up-arrow or down-arrow keys.
Feb 24, 2013 | Texas Instruments TI-84 Plus Calculator
Calculator turns on, but cannot turn off and no other buttons work.
4. Turn on the unit
Aug 28, 2012 | Texas Instruments TI-84 Plus Calculator
Does not responce, can't turn it off
If the TI-84 SE does not function even though you are sure that the
1. Remove all of the AAA batteries from the graphing handheld.
2. Press and hold the ON key for ten seconds.
3. Replace the batteries.
4. Turn on the unit.
May 29, 2012 | Texas Instruments TI-84 Plus Silver...
My graphing function doesn't work for trigonometric functions.
The angle unit is not conform to your problem.
If angle unit in your problem is degrees, change angle unit to degrees on calculator.
Then change the Xmin, Xmax values to about -180 and 180
Sep 13, 2011 | Texas Instruments TI-89 Calculator
When attempting to solve graphing equations GETTING graphing error says INVALID DIM
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't do it, please reply to this post and give a sample equation that causes this error.
Sep 09, 2011 | Texas Instruments TI-83 Plus Calculator
I spilled gatorade on my TI84 graphing calculator..what should i do?!
Do not attempt to turn the calculator on for several days. Remove the batteries. Once the electronics (battery compartment especially) is dry, you can attempt to power it back up and it may or may not work.
Mar 03, 2011 | Texas Instruments TI-83 Plus Calculator
How to use graphing calculator?
The casio FX-300Ms calculator cannot do graphs. To tell you how to use a graphing calculator TO DRAW GRAPHS we need to know the exact brand and model number of the calculator.
  1. Most graphing calculators basically function the same way.
  2. You select the graph type (function, polar,parametric, sequence, 3D, wire mesh, slope field, etc.)
  3. You enter the algebraic form of the function you want to draw.
  4. You press a button or menu to GRAPH
  5. The graph is drawn.
  6. If you want to see a particular part of the graph, you use a ZOOM function, or you enter values for the WINDOW dimensions.
  7. Most graphing calculators have a TRACE function that allow you to follow the curve you have drawn to read off values of coordinate points.
  8. You can also use the calculator to find zeros roots) of functions, calculate derivatives at some chosen points or calculate the area "under the curve", find the minimum and maximum of a function.
In addition to its graphing capabilities, a graphing calculator can be used as a scientific calculator. Sometimes it can also do statistical and financial calculations, matrices, list manipulations, operations on complex numbers, text editing,, creating programs etc.
Aug 13, 2010 | Casio FX-300MS Calculator
Texas Instruments TI-83 Plus Silver Edition Calculator Logo
387 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
