Question about HTC Touch P3450 Smartphone
It just losses power and turns off. when i restart sometimes it doesnt start (in this case i have to remove the battery and put it back again), sometimes it starts but the screen backround becomes red and shuts down is it dead? :)
  • 1,223 Answers
Just try this
when ur pda is switched off press Call and end key together and then press power button for like 5 sec a screen will appear asking u to format the pda pls confirm the action by pressing center button of the 4 way keys and then ur pda will be factory reset to the default OS , if it helps ur problem then tell me
other wise go and upgrade ur ROM from it will help u for sure basically it is a software issue
have u ever tried to update ur pda thru custom rom if yes then there is a bit checnge in the process pls let me know but u can try the reset thing it will work
pls rate me fixya if i fixed ur problem
Posted on Mar 04, 2009
My car doesnt start
Sometimes the battery will be good enought to run lights but will not turn car over. I would have battery put on a full charge and see if it holds up. if battery will not hold a full charge it is bad. If your car runs and the battery last a few hours then goes low again, It most likley is the alternator. put battery back on full charge and replace alt, and you are ready to run.
Apr 11, 2012 | Cars & Trucks
Mazda 5 wont start has new battery
mazda5 2006, started to not start, will crank over then dies out? could this bea starter? doesnt have loss of battery power? all the lights and radio turn on, jsut when i start it sometimes the engine comes on then will stall... thanks in advance.
Apr 08, 2012 | 2006 Mazda 6
Some times the phone signal freezes (it shows some lines of signal but you cannot receive or make calls). I usually turn it off and on again and it starts to work but sometimes it is not turning off,...
remove your battery and leave it out for around 5minutes, when you put the battery back in, the phone should auto reboot, hence sorting out any problems it has, if this fails, contact BLACKBERRY DIRECT, they should solve the problem for you with a secret menu!!
Apr 30, 2011 | RIM BlackBerry Bold 9700 Smartphone
When I try to start io my netbook, it sounds as if the disk is going, like it does when it starts up normally, but the green processing light doesn light up and it starts to sounds as if the disk is...
1. turn off your netbook completely.
2. unplug the ac adapter and remove the battery
3. press the power button for about 5-10 secs
4. plug in the ac without the battery and turn on the system
-if still doesnt work unplug the power cable and press the power button for 5-10 secs
5. turn the netbook upside down
6. locate the memory door and reseat the memory
-make sure that the memory is properly installed from the slot
then put back the memory door and all the screw
7. restart the computer
Sep 06, 2010 | Acer Aspire One PC Notebook
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Guages when crazy. Now won't even try to start.
You likely have it repaired by now but it sounds like a classic case of oxidized battery or cable connection (sometimes mis-diagnosed as bad battery but cured with new (clean) battery)
Feb 25, 2009 | 2002 Jeep Grand Cherokee
I have a Toshiba Satellite P105-S6084 My daughter turned it on. Windows started to load and then everything went blank and the computer refused to be turned on again. No sign of power
Take battery out of the back of laptop, put back in. if that doesnt help:
1.) remove battery from back of latptop
2.) remove cmos battery should be accessable through one of the panels on bottom of latop.
Are you getting any beep codes?
Jan 20, 2009 | Toshiba Satellite P105-S6084 Notebook
My n70 always restart by its own...always freeze
turn your blueetooth on and you see that it will not stuck
Jan 07, 2009 | Nokia N70 Cellular Phone
Wont turn off
First, take the battery out and put it back in to reset it. Then try again to see if you can manually turn it off.
This resets the phone and is the first step in troubleshooting.
Another thing I would do, is test to see if there is something wrong with the end button itself. With a flip phone, normally the end button is unneeded because you close it to hang up. Try ending a call using that button to see if it is a broken keypad issue.
I would also have the local store update the firmware, which should repair any files that may be corrupted, if that is the case.
Also, if the phone has any water damage (when you open the back of the phone, there will be a red dot instead of a white one), this can cause all sorts of crazy problems.
If none of the above solutions work, the only other way to power your phone off is just to remove the battery. You should be able to put the battery back in without the phone restarting, but if it does, just keep the battery out when you want the phone off.
Jan 21, 2008 | Motorola Mobility RAZR V3
Power up problem
Hi, you most probably have a sticky on/off switch on your case. Turn the power off. Remove the side cover, trace your wires from the front switch to the mobo, identify witch is the power switch [this is usualy marked with PWR or PWS on the board and also on the wire from the switch. Disconnect this wire then turn on the power and use a fine screwdriver to bridge the two pins on the board, if all works properly then replace the switch Regards mistyman
Sep 06, 2007 | E-Machines eMachines T3830 PC Desktop
HTC Touch P3450 Smartphone Logo
52 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
