Question about Syntax SV266M Motherboard
I can only get in my computer in safe mode.....why
I just switched everything to another case and it will only load in safe mode
  • rebelmatt3 Mar 04, 2009
    i`m running windows xp pro and all i did was switch to anther case and now , it will only load in safe mode
    Sergeant:
    Champion:
  • 224 Answers
Are you running Windows Vista? In safe mode, click on start and type "msconfig" without the quotes. There is an option to boot only in safe mode. Change that and it should solve our problem.
Posted on Mar 04, 2009
  • Shakeel Muradali
    Shakeel Muradali Mar 04, 2009
    When you say you switched to another case, was the motherboard and other parts as before or was something else changed?
Computer not loading
Are you using Windows? This sounds like there is a problem with your boot sector and Windows is asking you to enter Safe Mode, Safe Mode with Networking, etc.
You can put in your Windows installation CD, if you have one, and repair the bootsector with the utility available on the disc.
If you save files to My Documents or anywhere else on the C: drive you could lose them if you have to reinstall Windows. You can reinstall Windows without deleting your files, WinXP only I believe. If you have to reinstall a factory image then that will overwrite everything on the target partition or drive.
Alternatively, you can use an external hard drive case to hook the hard drive up to then connect it to another computer. This will allow you to browse your hard drive contents and back up any important files that you have before reinstall your operating system.
Jul 06, 2012 | Computers & Internet
HAVING TROUBLE CLICKING ON SOMETHING AND COMPUTER LOCKSUP SAYING CLOSE PROGRAM OR WAIT!!!THIS HAPPENS OFTEN!! HPdv7 6163 i7 windows 7
Probably viruses. Try to load Windows in Safe mode, if everything is OK, there is a problem with system or viruses. Power on laptop, press F8 and hold until you get Windows loading options, and choose Safe mode.
Sep 04, 2011 | HP Pavilion dv9000z Notebook
My computer won't go pass the load screen.
load your computer up in Safe Mode. Whats happening is the 3-D parts of your computer that are loading, arent. Safe Mode only loads 2D parts. I would suggest looking online for a simple fix but this happened to me personally when i installed a new graphics card.
If this doesnt help, then you need to do a system recovery, with or without the disc. It could be that something in your System32 folder(everything that runs the computer) is messed up. Please check into this as well.
Hope this helps!
Aug 09, 2010 | Acer Aspire One AOA150-1949 Laptop
Wont get past Microsoft Windows XP loading screen on Acer Aspire1
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 17, 2010 | Acer Aspire One AOA150-1126 Notebook
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
Gibberish + won't finish loading Windows
remove the new memory first. if that does not help you may have some a virus, indicated by safe mode workng fine. One other thing i found would do that is a damaged Hard drive, not to likely here because safe mode works.
Apr 28, 2009 | Dell Dimension E521 PC Desktop
Computer keeps shuting off automaticly
your computer is virus infeted.
when upower up the computer prerssF8 key then enter in safe mode.
then type "msconfig" in run then go to stratup it is last tab
then disable all stratup then restart your computer.
also if u have updated antivirus like avast scan your computer in safe mode.
Mar 26, 2009 | E-Machines eMachines Desktop PC
My system will only work in safe mode
you have a driver issue.I would suggest formatting and reinstalling xp,or use live chat to walk you through finding and removing bad driver.
Mar 04, 2009 | Syntax SV266M Motherboard
Can't get to login window
Blue screens are normally critical errors. If you have loaded any new hardware to your computer lately or some software packages you will need to uninstall them.
Try starting windows in safe mode by pressing F8 continuoulsy until you hear a beep. This will start the computer in safe mode and everything will look big on the screen, ignore that for now. While you are in safe mode uninstall anything that you have loaded prior to this error. Be it software or hardware.
If you have not loaded anything recently then try restoring your computer to an earlier time when you know that it was working with now problems.
Once safe mode boots go to Start>all programs>accessories>system tools>system restore and choose a date when you know that the computer was running okay. Once the restore has taken place the computer will reboot. If asked what mode you want to start in choose start windows normally.
Hopefully this will help you resolve your problem.
Nov 11, 2008 | IBM Computers & Internet
Startup
Possibly 2 reasons:
1. Driver/hardware/software/application problem; or
2. Virus/malware.
You can consider:
1.1 Run in last known good configuration that worked (by pressing F8 to display menu choices prior to Windows boot);
1.2 In safe mode, Start/Run/type "msconfig" minus the quotes, uncheck everything in the Startup tab, reboot;
1.3 In Safe Mode, run your antivirus or run Kaspersky online virus scanner or anything similar;
1.4 Download/install/run AdAware or anything similar;
1.5 Check you Control Panel for devices with yellow or red markings;
1.6 Set your BIOS/CMOS to conservative/default/best performance settings (normally press Del on powering up);
1.8 Check/Clean your hardware: video card, memory, fan/blowers etc;
1.9 Booting without any USB devices plugged in;
Worst case scenario, use a recovery CD that came with your computer or in the absence of that, reinstall your OS using the 2nd "Repair" option.
Hope this be f help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 04, 2008 | Microsoft Windows XP Home Edition
Syntax SV266M Motherboard Logo
101 people viewed this question
Top Syntax Computers & Internet Experts
Gbenga
Roy May
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
