Question about Sony FD Trinitron KV-28FQ75 28" TV
Palsonic TV with built in DVD not working
Palsonic TFTV5535DT Tv with built in DVD player is brand new but the DVD player will not work. Dvd goes in, screen says "READ" then ejects the DVD without playing it. Help !
  • markbrandon8 Mar 27, 2009
    The DVD starts to play but the screen shows 'no signal'
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
SOURCE: DVD Stuck in player
Found out what my problem was - 2 DVDs were in the unit - need to take unit out of car (very easy - 5 mounting screws, 2 plug in power connections), remove some brackets from within the unit to get to the DVD itself and then just pull the DVD out - took me less than 1 hour - and I am not tech savvy or mechanically inclined by any means
Posted on Jun 29, 2007
  • 84 Answers
SOURCE: connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Posted on Apr 06, 2008
  • 12 Answers
SOURCE: Sony KV25XS
Try going here:
http://esupport.sony.com/
Maybe you can find the manual for it. The manual should tell you how to change the TV to video. But there is probably a labeled button called video on the front/side/back of the TV that switches it. Unless that is a function that is now on the remote.
Posted on Oct 02, 2008
welcomejee
  • 10594 Answers
SOURCE: Green symbol AV2 won't go away! Sony Trinitron KD-28DL11U
You need to have original Sony TV remote and press Display button on it, on-screen display will disappear.
Posted on Nov 25, 2008
How do I connect an older model dvd player (2008)to my older model tv set both of them are sylvania.
Your DVD /VCR has RCA (phono) connectors for the outputs. Check your TV has the same for the inputs. If it has buy a three way RCA lead from eBay.
Jan 03, 2015 | Televison & Video
S video displays, but Component video is intermittant
Shall we assume that the DVD is fine, before addressing the TV issues? Does it work with any other device or component? Seems that if your S Video is clean, then it's just a matter of refining whether your DVD is as well. Check that, and let us know.
Feb 12, 2008 | Hitachi 53FDX01B 53" Rear Projection...
How do i make my external dvd player work with my **** smith tv that has a broken internal dvd player??
If your TV has an HDMI input, and your external DVD player has one, then you can easily connect them.
Sep 04, 2014 | LG Televison & Video
The keys pressed on the remote does not correspond with what happens.
If the player is brand new and doesn't work right, take it back.
Jan 19, 2014 | Televison & Video
Connecting tevion DVD player to palsonic tv for first time in ages. The picture works, but the sound is only very faint, even if I turn up the sound to the maximum on both devices. How can I fix the s
Those cables are RCA jacks. You need to connect all 3...red white yellow. You dont need 5 like in the video. So on DVD Player connect red to red ...yellow to yellow.....white to white. Connect to audio/video out. Then on TV connect audio/video in or input same way red to red ...and so on.
Oct 06, 2012 | Televison & Video
Check disc
The DVD player's laser pickup assembly is intermittent and since it is brand new and under warranty take it back for replacement. There should be no issue with your TV set.
Mar 18, 2012 | Televison & Video
32lg40 built in dvd player disk error
There definatley could be a firmware issue with that TV's DVD player if the model has just been released.  My suggestion would be to bring a couple of known to be working DVD's back to the store and try their floor model as well.  This will be easier than bringing back the TV for the second time.  If this is a problem with the DVD player's firmware, LG should be able to fix it under warranty so I would call them or swap out the TV for another brand instead.
Mar 24, 2009 | LG 32LG40 32 in. LCD HDTV
UPCONVERT DVD PLAYER HDMI PROBLEM
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Jun 06, 2008 | Televison & Video
Sony FD Trinitron KV-28FQ75 28" TV Logo
209 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
