Question about HP Office Equipment & Supplies
Printer not listed
Hi im trying to install a printer but dont have the disc - hp photosmart c6180 this is not in the list either which other option can i use to be able to install - it is asking for compatible software
Please help new to all this
    President:
  • 1,073 Answers
Hi M8!
Follow this link:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1153494&lc=en&cc=us&dlc=en&submit.y=2&submit.x=6&lang=en&cc=us
Select you OS, download the drivers, intsall the drivers you downloaded and follow the instructions given during the installation.
Let me know how it goes!
Good luck
Nic
Posted on Mar 04, 2009
How to install hp photosmart c6180 without the disc
Welcome to Fixya
If you dont have the disk with you. All you need to do is to plug in the printer to your computer and download and install the driver from HP website. Make sure you select only the correct drive for your windows system. for example, if you are using windows XP you should download windows Xp dirver also.
Thank you for using Fixya!
Jan 12, 2011 | HP Photosmart C6180 All-In-One InkJet...
Will not connect with computer
Click Here and Select your Operating System from the list and download drivers then install it and connect your printer.
Please rate my response!! Thanks, SF
Jan 28, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180. I can't check ink level on my computer
Not all printers have this option, but i think this one should. you may need to download and install the software, you can do that from here: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=id〈=en&product=1153494
Try the HP Photosmart Full Feature Software and Drivers and the HP Printing Diagnostic Utility
give that a go. Hope this helps
Jan 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
My PC keeps listing my Photosmart 6180 as
The option should be there by right-clicking it.
Dec 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cannot get Printer reinstalled after having Hard Drive replaced.
first you need to installed the sytem driver like mothrboard driver and the display driver then start installing the printer driver if you dont have printer driver you can download from this link,
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1153494&
Nov 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 won't scan documents
Suddenly since last week I can not scan to my E Mail or iphoto anything. It simply says -" sorry scanner can not be initialized. Error communicating with scanner
Feb 22, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ilost the installation disc for my HP Photosmart C6300 All-In-One
Welcome to Fixya !
You can search and download the drivers and firmware software required to use your HP priter from this site - > http://welcome.hp.com/country/us/en/support.html
Just enter the exact model no and the operation system you are using to get the download options
Rate the solution as Fixya if its solves your problem .
Feb 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ben Johnson
