Question about OKI MICROLINE 320 Turbo Matrix Printer
I want oki ml 320 turbo driver.. eny body can help me on that..?? pls,,,,,
  • twnygal Mar 28, 2009
    I have a similar problem and this solutions work for me. paper feed 1 inch too high.
  • 65 Answers
the oki data ml 320 driver should be bundle with the operating system. If not you can download it from okidata website.
http://okidata.com/mkt/html/nf/Drivers.html
Try it and let me know if this helps.
Thank you.
Posted on Mar 28, 2009
I need the driver for a OKI GE7000A
Same as Oki ML-320.
From this link,
Select your'e Operating system and you're ready to go
good luck
pls. vote for better sharing... thank you
Nov 20, 2010 | OKI Office Equipment & Supplies
Okidata 320 turbo microline prints jibberish
sounds like a job was sent to the printer with the wrong driver. There is no way to purge it just load some paper and let it run until it stops. They make sure your emulation matches the driver youa are using. Example Epson 9pin compatiable or OKI ML320 Turbo-IBM drive you want the emulation set to Epson FX. Or if using the OKI ML320 Drive you want the emulation set to ML.
Jan 15, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 320 turbo
Are you using the parallel or serial port ? .And what driver are you using ? if correct driver is being used maybe delete and re-install the driver.
Hope this helps.
Dezzi
Oct 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 320 turbo
Your Oki model does not need drivers, for they are already contained since Windows 98 and up. However, if it still doesn't work, check that the printer emulation is set to IBM and then install a new printer using the IBM Proprinter II/III driver, also contained in Windows.
Be blessed.
Oct 02, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki ML 320 Turbo
Check the menu settings in the printer is the emulation set the same as your previous printer.
Dezzi
Jul 23, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
1,196 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
