Question about Mr. Coffee ECM20 Espresso Machine
New Mr. Coffee Espresso machine producing white gunk
I just got the Mr. Coffee Steam espresso machine. Running the first cycle with just water produced white flakes in the carafe. I ran it again with just water. Still a lot of particles in the carafe coming out of the machine. I have since run it about 20 more times, and it is still producing lots of white stuff. I have rinsed the resevoir repeatedly. I have used a descaling agent made for coffee makers, and nothing is helping-- every batch has some amount of flakes. What IS this? Is it fixable? Should i start over with another Mr. Coffee, or is this a common problem? I don't want white floaty bits in my coffee.
Hello aura20,
I bought one this week and had the same problem. I used vinegar and rinsed thoroughly and yet the whit flakes remained. I did some research and found that high end espresso makers often have very fine screens that catch minerals and grounds and so on. This Mister Coffee espresso maker has only a metal basket with tiny holes so it's not really filtering anything. Moreover the metal is treated aluminum, so it scales naturally. Also, if your water is hard like mine that just makes things worse. I just tore off a piece of paper towel only big enough to line the bottom of the filter basket and not come up around the edges. Then I put a drop of water on the paper towel and pressed the paper towel against the filter basket so I could see the little holes through the paper towel. Then I rinsed the machine again and the white flakes were completely gone from the water and the paper towel had collected it instead. I did the same thing with a new piece of paper towel and I added coffee, I did not add the maximum amount of coffee and I did not tamp the coffee. The product was smooth and creamy as it came out of the machine very slowly. But it tasted great and it was strong and clean. Upon removing the basket I found hard dry grounds stuck to the basket and paper towel. I had to use a spoon and running water to dig all of it out. It's not as good as professional espresso makers, but it'll do for a quick shot. I hope that helps.
Posted on May 20, 2009
No water coming out
Espresso Makers FAQs at MrCoffee.com.
www.mrcoffee.com/.../espresso-makers/espresso-makers-faqs....
Mr. CoffeeBrowse our Espresso Makers FAQs to find answers to common questions about Mr.Coffee products. ... Why isn't espresso coming out when I try to brew a cup?
Steam Espresso & Cappuccino Maker (ECM160-NP) - Mr ...
www.mrcoffee.com/.../mr.-coffee...espresso...maker...-/ECM1...
Mr. Coffee
Rating: 2.7 - ‎32 reviews
coffee-steam-espresso-and-cappuccino-maker--ecm160-np-/ECM160-NP.html ..... Thecoffee grounds don't come out wet like the other unit. ..... too much as the steam pressure only (no pump) isn't enough to force the water through the "cake".
Repair Your Clogged Coffee Maker - Instructables
Dec 21, 2015 | Mr. Coffee Coffee Makers & Espresso...
Machine is clogged and water will not drip through to make espresso. the steam frother works sort of
Did your User Manual have a section that tells you how to clean out mineral deposits and hard water scale? Usually, this is done by filling the resevoir with white vinegar and then turning the machine ON for 30 seconds then OFF for 5 minutes. Keep repeating the ON-OFF cleaning cycle until all the vinegar is pumped into the carafe. If the machine needs further cleaning. Repeat the process until the scale and mineral deposits are dissolved. Finally, flush the machine with a full resevoir of clean water and run a normal BREW cycle. Should work like new.
Apr 25, 2015 | Mr. Coffee ECM20 Espresso Machine
Slow dripping and ground cup is extremely hot
Have you tried cleaning your coffee maker? If not just fill half of the carafe with white vinegar and let it brew. Keep basket in during cleaning but no filter needed. After running the vinegar through the brew cycle, fill the carafe with plain water and run fresh water through about 3 to 4 times. I do this every 4 to 6 months. I have a light on my coffee maker that lets me know when I need to clean it. I hope this helps.
Feb 27, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
How to clean the coffee maker?
The easiest way is to run a cup of white vinegar in half a carafe of water through the brew cycle, followed by at least one carafe of clean water.
Jul 16, 2014 | Mr. Coffee 12-Cup Programmable Coffeemaker
Mr Coffee Pump Espresso machine not working. Lights alternately flash between coffee and steam icons, machine makes noise, but coffee does not brew, water does not flow, steam does not come out.
The espresso portion may be clogged with hard water deposits, and the steamer tube with casein. Run a tank of plain white vinegar a couple of times then run a couple of tanks of plain water to flush the vinegar, Open the steam valve while the espresso portion is running and set the steamer pot under the steamer. Don't be surprised if a long white tube of hard white material slides out of the steamer valve. That's the casein, actually a form of organic plastic.
Sep 27, 2013 | Mr. Coffee Coffee Makers & Espresso...
Flakes/Particles coming out of the steam nozzle.
hi there,
the small flakes are bits of lime scale from your boiler system, to fix/ reduce flakes/particles complete a de-scale cycle on your machine using de-scaler. water hardness- set on 1 will change the length of time before it will ask you to de-scale the machine. Note- hardness 1 is the max time length. hope this helps
Feb 23, 2012 | Saeco Royal Professional Espresso Machine
General question about the Mr. Coffee Espresso ECM10
Greetings!
Put desired amount of water in resevoir (plus a little extra to be used to steam your milk for latte) and close up tightly.
Put espresso grind coffee in basket and tamp down with a tamper. If grounds are not packed, steam will seep through and will cause an erosion of sorts instead of just letting the steam hit the grounds.
Put the basket with handle group in recess rotating to the right as far as it will go.
Rotate the ON/OFF switch to the symbol for "Brew" until you get out the desired amount of espresso.
Then, take a caraf of milk and immerse it with the plastic black steam arm. Rotate switch to "STEAM" and froth milk. In the beginning, ensure that you have enough water for the espresso AND enough left to froth without having to shut off machine, refill with water, just to froth.
Be careful when you open the water resevoir cap after brewing because there is a vaccuum created and a burst of steam will shoot out the lid and may burn you.
The gasket above the grounds hopper eventually will deteriorate and more steam will escape than espresso is produced. There is no replacement parts for this machine since it was made in China according to a Mr. Coffee representative that I called this morning at 1-800-MR-COFFEE (800) 672-6333.
Good luck with your machine. Hope this helps! If you don't have a tamper for the grounds, I found one at Bed Bath and Beyond. It is stainless steel with 2 sizes. The smaller size works for this model.
Jan 17, 2009 | Coffee Makers & Espresso Machines
No steam!
Ran into the same problem on mine just after using the steam, so it definetely wasn't clogged... hope this helps.
Just try running the expresso maker through a full cycle and then try the steam again. Not sure if the machine air locked or something, but the expresso cycle appeared to get the water flowing again and then it had no trouble producing steam.
Hope it works.
Jan 11, 2008 | Hamilton Beach 40729 Espresso Machine
Mr. Coffee ECM20 Espresso Machine Logo
1,255 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
