Question about Hotpoint HSS25GFP Side by Side Refrigerator
The refrigiator was working correctly untul i had it open for about 20min while cleaning,it swiched itself off and will not come back on?????
  • 400 Answers
Close the doors, switch off power supply completely for an hour, then switch on again.
Posted on Mar 04, 2009
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Refrigiator does not air culation
tihs is either a ice blockage on the cold coil or the evap motor has failed ... hope this helps mm feed back pls .. ,,
Jul 10, 2011 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
What are the two plastic (square)on he top of refrigiator? Sould I remove the straform in inside the plastic?
Yes remove it. It's just packing material to keep any moving parts from braking and may be blocking air flow.
Aug 29, 2009 | Refrigerators
Freezer works, refrigerator does not cool
Often the cooling section is located in the freezer and their is a hidden fan that blows the cold air into the lower section. If the fan quits working the refrigiator section wil not be cool.
Jun 19, 2009 | Refrigerators
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
GE side by side fridge/freezer. Fan in fridge is not spinning.
Replace that fan that blows the cold air into the refrigiator.
Jan 06, 2009 | Refrigerators
Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Mar 30, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Control panel inactive
Your refrigerator is in demo mode. Review your manual on how to remove it.
Feb 24, 2008 | Samsung RM255LASH Side by Side...
Bad smell from vent at back of fridge but able to remove back panel
if you cant remove it then wash it unplug the refrigerator from ac outllet first then remove the carton cover in the back and you gona see the pan were the water is temporaly storege with a garden hose washing the pan and then clean the floor use or news paper around the refrigy is helpfull the water or so in the pan is evaporated with the hot of the compresor sistem that water come frome the freeser compartment....good luck and rate me
Jan 11, 2008 | Samsung RS2630SH Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
