Question about Emerson Fans 300 Heating & Cooling Thermostat
Vulcan 300 Freeloader Gas Water Heater
This water heater turns off every time we have a windy weather. I turn it on many times, it works for a little while but then turns off after sometime. At times it also turns of on a fine day. Please help me, it is driving me crazy and i can't bear cold showers in the mornings
  • Anonymous May 12, 2009
    I have the same problem and it is driving me insane. I also find starting the pilot light a problem as soon as you release the button it will go out and this will happen numerous times before it stay alight.
    I have tried blowig air on the pilot light area, the light stays on until I release the button then goes out. Any suggestions please ?
    Guru:
  • 462 Answers
I assume it has a pilot. Try blowing out the pilot area with compressed air or CO2. Then relight the pilot.
Dust can cover the pilot combustion air inlet and cause it to pull away from the safety generator or thermocouple. Its called an oxygen depletion arrangement on some space heaters. I assume your Domestic Water Heater has this setup as well. Even if not the thermocouple is not getting all then heat from the flame. If this doesn't work get back to me here. We'll try 1 more thing.
If this helps you please grade me accordingly. GOOD LUCK
Posted on Mar 04, 2009
To hook up gas, to an Vulcan 260 freeloader
best left to a pro . gas leaks cuase explosions when we certainly don't want one
Jan 21, 2015 | Water Water Heaters
Low hot water pressure
I am not familiar with the model of heater you have but I thought I would mention; if you don't have a water softener and the thermostat is set to 140 degrees or above in a hard water area limescale can be a possible cause of your problems and it would be wise to take a look inside before you begin throwing money at it.
Feb 13, 2018 | Water Heaters
I have a new windy watch but dont know how to set the date and time on it could anyone please help me?????
annoyingmist, let me try.
1.by windy you mean mechanical?
2. if yes, then move the hands clockwise watching the calender until new date appears.
3. now turn hands anti- clockwise a little and clockwise again. Keep doing until you get today;s date.
4. set the watch to correct time. good luck.
Dec 25, 2013 | Watches
I have a Paloma Whole Home 7.4 GPM Water Heater, it is a propane heater. I bought this heater in 07 and I get the same problem ever year. When the weather gets cold and the water is cold the hot water...
If incoming water is too cold, tankless might not have enough time to heat the water as it flows by insince the heat exchanger.
1) You can passively preheat cold water using staging tank, or tampering tank.
http://waterheatertimer.org/Tempering-tank.html
2) Buy old water heater from plumber that is not rusted out.
Replace anode rod to stop further rust.
Rinse tank with water and hydrogen peroxide to kill bacteria that results from anode rod.
http://waterheatertimer.org/Replace-anode-rod.html
Clean sediment out of bottom:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
3) Don't forget, a tankless heater needs to be de-limed each year, and cannot be exposed to more than 11 grains hard water.
4) Since all costs are energy, when you get tired of messing with tankless.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/images/Compare-water-heater-parts.jpg
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 18, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Bosch AquaStar tankless natural gas water heater pilot goes out periodically--after a few hours or a few days, whether weather hot or cold, whether windy or not. This condition has been the same from day...
I had a similar problem with mine and it turned out to be a plugged air vent sceen. This is the small dome like sceen on the gas valve. I vaccumed out the unit and have not had the pilot go out in over a year.
Nov 27, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a vulcan freeloader 260 gas, how do i make sure it has water in the tank
The old freeloader is feed by cold at the bottom and the hot feed comes out the top. Basically if you are getting hot water out the hot tap (or any water out the hot tap) it has water in it. If you have any concerns post a new fault, I will keep a look out for it. These are great heaters, well worth looking after.
Sep 20, 2010 | Heating & Cooling
My reliance water heater pilot goes out every time its windy i have to relight it 5 or more times a day
You need to extend the flue vent 2 feet above the roof ridge-line. This will help eliminate the low pressure suction on the pilot light.
Sep 08, 2010 | Reliance Water Heater #6-30-YORT 30GAL NAT...
Emerson Fans 300 Heating & Cooling Thermostat Logo
1,081 people viewed this question
Top Emerson Fans Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an Emerson Fans Heating and Cooling Expert? Answer questions, earn points and help others
