Question about Syntax SV266M Motherboard
Syntax sv266m motherboard....it wont go past the windows xp scree
I switched my syntax sv266m motherboard to another case and now when it boots up i get the windows xp pro screen and then it never brings up another screen,,,,what could be my problem
  • rebelmatt3 Mar 04, 2009
    this didnt work, do you have any other suggestions?
  • Mark Anthony Cassar
    Mark Anthony Cassar May 11, 2010
    So it's freezing or it just keeps trying to load? As that could be a different problem from the other. Have you only switch the motherboard around and kept the RAM and HDD etc? There could some kind of problem with those peripherals. If you have access to RAM Diagnostic Software (Gold Memory or memtest) try checking your RAM.
Check if the safe mode is working..?pressing F8 just b4 windows xp screen comes up...
if yes then good...
check if u seated the ram properly?.and check if its showing the full amount of ram in the bios page..
Posted on Mar 04, 2009
Hola amigos mi pregunta era saber cuanta memoria aguanta el mother sintax sv266m(a)
a sintax sv266m memoria m?xima que se puede utilizar en la placa base es de 2 GB
Aug 02, 2011 | Syntax SV266M Motherboard
No video onboard, se provó
Hice downgrade a la bios por la versión nM916.bin (buscala en driversguide como: SV266M_RealTek.zip) y NO! SV266M_ICS.zip porque luego de flashear no arranca mas.
Dec 15, 2010 | Syntax SV266M Motherboard
Syntax SV266M
if you go to this link.
you will need to sign up its free to sign up.
http://members.driverguide.com/driver/detail.php?driverid=350098&si=cb50455104f1d4b8bed38935cfebe1bf
this should help you
Good Luck
Happy Computing
Jan 10, 2010 | Syntax SV266M Motherboard
Drivers needed for syntax sv266m motherboard
You can try following links for downloading the drivers:
http://download.driverguide.com/driver/SV266M/Syntax/d350111.html
http://ar-domena.com.pl/sv266m/
Nov 04, 2009 | Computers & Internet
I cant find syntax's website to download a flashing utility and the bios image.
HI timereillyis,
The Syntax-Brillian Corporation maker of the SV266M Motherboard, In May of 09 all assets were acquired by Emerson Radio Corp. Now, I don't think Emerson is going to support that motherboard, however, you can can most of your drivers, from HERE. You may need to create a login, but I'm pretty sure they will have what your looking for.
Thanks
Mark
Oct 21, 2009 | Syntax SV266M Motherboard
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
My system will only work in safe mode
you have a driver issue.I would suggest formatting and reinstalling xp,or use live chat to walk you through finding and removing bad driver.
Mar 04, 2009 | Syntax SV266M Motherboard
I can only get in my computer in safe mode.....why
Are you running Windows Vista? In safe mode, click on start and type "msconfig" without the quotes. There is an option to boot only in safe mode. Change that and it should solve our problem.
Cant get past windows xp screen
http://downloads.drivershq.com/DD/driverfiles/5/DriverDetective.exe
Here is what you need!!! Click on the Above Link. Download Software!!!
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
No audio
Hey there,
You dont have to worry about anything.
go to you manufacturer web site in the search pane type your M/B Model no. And download the drivers. this is the best way to download.
else Go to google and type for "download Drivers for .........Your m/b Model no". Select one of the site who are providing drivers.
Thanx
Romy
Aug 07, 2008 | Syntax SV266M Motherboard
Syntax SV266M Motherboard Logo
359 people viewed this question
Top Syntax Computers & Internet Experts
Gbenga
Roy May
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
