Question about Refrigerators
Iceicles form on underside of ice maker
Replace selenoid valve today figuring it had calcium build up or that it was failing. It appears to NOT have been the problem. Still getting iceicles forming.
  • 410 Answers
It sounds like maybe the Icemaker itself is leaking. under the white strippers on the side of the icemaker there is normally a silicon seal that prevents water from spilling out during fill, over time this seal erodes and needs to be reapplied or if the icemaker mold has coroded real bad you may need to replace the icemaker. food grade silicone grease is available thru whirlpool and the part number is 542638 you will have to take the stationary stripper off of the side of the icemaker and clean the surface between the mold and stripper then apply the grease in a lite film. if you have any further questions please ask thanks Peyton
Posted on Mar 04, 2009
Long time not using the ice maker, today I tried an is making ice
I would replace the water filter first off. If you have completed that already then I would check the water fill outlet for calcium build up. If that is clear, check to make sure the solenoid is energizing for the fill. If you have water to the basin and it is still not working I would have to check the timer to see if it is initiating a cycle for the ice.
Apr 08, 2014 | KitchenAid 18.5 cu. ft. Bottom Freezer...
Ice maker not making ice
The probelm is your not getting enough water to fill the ice maker up. This could be caused by a variety of things. I'll go over the most common ones.
1) Check the water filter. If the filter is out of date or has a severe enough calcium build-up it will restrict water flow
2) Is there a blockage in the fill tube of the icemaker?
3) is there calcium build uip at the valve? Turn the water off and remove the water line from the valve and inspect.
4)The valve may be going bad not allowing the solenoid to open completly causing less water.
With all that said there is a place on the icemaker itself that the water level can be adjusted, but be cautious. Too nuch if a turn and you may end uo flooding your kitchen.
May 20, 2012 | Frigidaire Refrigerators
Our ice maker leaks water and forms mini iceburgs inside our frezer. It appear to a water leak leading to the ice maker. What part should we replace to fix this problem. It is a Kenmore SxS 26' SS...
Your water valve probably has a drip like a bad water faucet.The water valve is cheapest and your only 2 parts options are the ice maker AND the water valve.
Sep 08, 2011 | Kenmore 57703 Stainless Steel
I recently replaced the evaporator fan motor. Now I have two problems: 1) Ice maker does not dump ice automatically. The water line is clear and fills up the tray. The ice freezes but will not dump the...
Hi and welcome to FixYa, I am Kelly.
You made this statement:
I have to manually make the ice dump. 2) I now have a slight build up of ice under the ice maker where it appears the water from the ice tray is leaking and the inside of the freezer also has a slight build up of frost on the walls.
From my 40 years of experience that statement is telling me that the freezers' evaporator coils are blocked with ice. (i.e frost on the walls) When the coils become blocked or built up with ice everything APPEARS to be working fine but the actual freezer temp is above 17 deg F. An ice maker will not initiate an ice-harvest cycle until the temps are between 14 - 16 Deg F. I.e it is not cold enough to automatically make ice because the ice maker thermostat is not closing at 14 - 16 deg F to start the ice harvest.
So I will pose these questions for you and answer them:
Q? What causes the ice on the walls
A: The unit is not defrosting properly.
Q? What causes a refrigerator to not defrost properly?
A: There are several; reasons that a refrigerator will not automatically defrost
1. The defrost control has failed (Most common failure)
2. The defrost heating element has failed
3. The defrost thermostat has failed
4. A wiring problem in the defrost circuit
Now.... you also made this statement:
You may have a leaking ice tray but it is quite rare. What usually causes an ice build up directly under and ice maker is the inlet water valve leaking / bypassing water when it is supposed to be shut off. An inlet water valve will bypass water when the internal diaphragm fails or debris is blocking the needle seat of the diaphragm. Either way the only remedy is to replace the inlet water valve because the valves are NOT repairable.
Reach inside your freezer and squeeze the rubber tube that fills the ice maker with water. If there is a problem with the inlet water valve the rubber tube starts freezing up with ice. Eventually when the rubber tube is totally frozen the plastic tube on the back of the refrigerator that connects to the rubber tube either leaks or separates from the rubber tube and ports water onto the floor.
If you really want to prove that there is a problem with the inlet water valve turn the ice maker OFF. Remove the plastic tube from the rubber ice maker fill tube (Just pulls out) and place it in a bucket overnight. IF you note water in the bucket the next day then the inlet water valve has for sure failed. Sometimes they LEAK intermittently when the failure first begins so the bucket test may not reveal a leaking inlet water valve. The key here is you said you have water UNDER the ice maker and you suspect a tray leak.
Here is what I recommend you do after the overnight plastic tube in a bucket leakage / bypassing test:
1. Reinstall the plastic tube on to the rubber fill tube.
2. Turn the ice maker ON
3. UNPLUG the refrigerator and so a manual defrost by removing the freezer contents then directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess)
4. Return the unit to normal service
5. Check for ice production 6 - 8 hours after you performed the manual defrost.
If you have automatic ice production you most likely have and automatic defrosting problem... BUT.... there can be a problem with the freezer door / light switch. The door light switch is a 3 contact switch. One contact is a common power wire and the other 2 contacts turn on the light and provide power to the ice maker (and some times the evaporator fan also depending on unit design)
Test the door light switch amd make sure the light will go off when the door is closed. (depress the plunger) If the light stays on the door switch is bad.
Hopefully you have enough information to understand what is happening with your refrigerator and what the causes of the symptoms you have are.
I think in the end you will have to repair the automatic defrost problem and replace the inlet water valve. Do not forget about testing the door light switch.
Thanks for choosing FixYa,
Apr 14, 2011 | GE Refrigerators
Water continues to leak from the ice maker into
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve may be staying open. It's on the back where the water supply is connected. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it.
Jan 06, 2010 | Refrigerators
Ice maker will not make ice. no ice is being made. no water appears to be in ice cube making area. can hear a ticking noise from icemaker area
Carefully pour water from small glass into ice maker, until the cavity is near filled. Wait a few hours. If it dumps ice, you can usually rule out the ice maker.
If ice maker dumps, then it will be either a bad water valve, Ice building up in fill pipe going into the icemaker, or blocked water line that runs from your water source to the machine.
Caution. If the fill tube going into the ice maker is filled with ice do NOT
use heat such as a hair dryer to melt it. It will melt things you do not want to melt. If it is this problem, you must also replace the water valve because it is leaking slowly causing your problem.
Lastly, in rare cases, the microswitch in the ice maker fails and does not allow water to enter the icemaker.
Oct 22, 2009 | Kenmore Refrigerators
Ice Maker does not make ice.
Your water feed to the unit is controled by a needle valve and could be filling up with calcium, to fix this you can take the unit apart and soak valve in a solution that will break down the calcium. Often it is easer to replace the unit or the valve, most things you use to decalcify the valve can also damage it at the same time.
Aug 24, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Water valve leaks when power off to ice maker
replace the water valve..sounds like the solenoid has failed or possibly has calcium build up so it doesn't make a water tight seal when closed.
Jan 23, 2009 | KitchenAid KSRS25IL Side by Side...
Kenmore Side-by-side Ice Maker
The only cleaning that can be done is at the inlet valve. If it is anything else you will need to replace it.
Dec 09, 2007 | Kenmore 44109 / 44102 Side by Side...
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
