Question about SanDisk Sansa Clip MP3 Player
SANDISK 2GIG no longer plays mp3s
Here is my situation.
I have a Sandisk Clip 2 gig MP3 player, with microphone and FM tuner. I went for a walk, selected a song and clicked play. Nothing happened.
I tried the button "Reset All" which should return it to factory settings. Nothing. FM radio still works, MP3 does not.
Went home, plugged it in to charge. When I enter the filing system in Windows Vista, the Clip shows 1.5 gigs "used space" (which is the size of what was on there) and 0.5 "free space", which is in line with what is free.
This is where it is strange. The files do not appear to be there, as in, all files are hidden, and the directories show minor/empty sizes (ie: 16kb). All files have suddenly become hidden and unplayable.
What to do to recover my music and voice recordings? Thanks for your help, in advance.
  • 8,596 Answers
You have to format the player to restore it to normal - unfortunately, it will result in all of your songs being erased, so make sure you have backups. The user's manual has the directions for formatting the player. Later, you will have to reload the songs.
Mp3 players are terrible for jogging, exercise, etc. because sweat can travel down the headphone plug, into the jack, and into the electronics.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 08, 2009
Fm tuner works but the screen is blank. brand new, just got it today...
You should update your device with new firmware at http://forums.sandisk.com/sansa/
Depend on your device Clip or Clip+.
Good Luck
Jan 27, 2010 | SanDisk Sansa Clip MP3 Player
How to turn off an FM tuner mp3 player
Normaly with most generic MP3s you press and hold Stop or Pause. You got a make and model on this one?
Apr 22, 2009 | Sony Walkman Bean NW-E305 MP3 Player
Sansa clip - not able to playlist listen on car radio w/ adapter
1) Go into the settings menu, go to FM settings, and make sure the FM Region is set for United States. If you are outside the US, change it to "World"
2) The radio might initially be set for Pause - to test this, turn to a specific radio station that you know you get, and press up on the clickwheel. The "block" icon underneath the radio station should now change to a play arrow, if indeed it was on pause.
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Did you get your fm tuner to work?
Switch the USB Mode in your settings menu away from the mode it is in now, and try again.
Dec 18, 2008 | SanDisk Sansa Clip MP3 Player
How do I turn on the FM radio?
The headphones are the antenna, you may have to walk around to get better reception. I've never found the radio reception to be great on t. A full manual is available for this product on Sandisk's website.
-Tha Mp3 Doctor
Dec 02, 2008 | SanDisk Sansa Clip MP3 Player
Sandisk sansa mp3 2 gig pink player
i tell you connect to the computer your device
and right click on your device and format it
and refill the songs
Jun 08, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e140 just need some help with menus
When you power on your MP3 player it will go to the FM radio. 1. Press menu.
2. Go down once and you'll be on "Mode". Press the right button to access the mode menu.
3. You either press the enter button after accessing the menu or go down to select Playback mode (I forget which one it is).
Good Luck!
Dec 26, 2007 | SanDisk Sansa e140 MP3 Player
Added storage
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
Jun 11, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
134 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
