Question about KitchenAid Dishwashers
Kitchenaid dishwasher is busted! model KUDS02SRBLO
I have no idea what's going on with the dishwasher, please help!
I have a black KitchenAid dishwasher, model KUDS02SRBLO. We came home to dirty dishes and blinking lights. The dishwasher starts out with a solid green light over the "quick clean up" button after I unplug it and plug it back in. Then, after I press a few random buttons in hope of fixing it by luck, the "normal" and "quick clean up" buttons blink simultaneously in rapid succession.
I unscrewed and looked behind the kick panel for the troubleshooting instructions but it's a little more than a layman can easily understand. According to what I found on the troubleshoot guide, I suspect that it has to do with some sort of shorted circuits. Please help!
  • 2326 Answers
SOURCE: KitchenAid 24 in. KUDI01ILBS...
The motor could be defective on this appliance and will need to be replace, it could also have a defective thermal fuse.
Posted on Apr 01, 2008
  • 6784 Answers
SOURCE: Glasses dirty looking and cloudy after wash cycle.
If there is not enough water, the dishes will not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film, or cloudy look after the wash cycle.
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Posted on Nov 16, 2009
  • 4 Answers
SOURCE: Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Posted on Feb 05, 2011
  • 17130 Answers
SOURCE: My Kitchenaid Dishwasher...The normal light is
Remove power and keep aside for few hours, Allow the internal voltages to discharge and thus reset if there was an error on the processor.
Before the power is plugged check the door safety switch and also connections to the controller unit. check the inlet vavle and drain pump, if short is suspected remove and check.
If the fault returns then we need to suspect the processor controller board.
Posted on Oct 10, 2011
SOURCE: Kitchenaid dishwasher Kudio1il 24'stainless
I'm having similar problem.I uploaded video of my attempt to reset and problem that I have after.I've already tried replacing my board... but have the same problem. The board was a refurb... so not sure if the board sent was defective - or if the problem is the control panel or something else?? thoughts?
Posted on Apr 01, 2012
Age of Kitchenaid dishwashr SN FJ06010185
Only Kitchenaid could give you that information. We are not Kitchenaid, we are FIXYA, a self help website.
Nov 27, 2017 | KitchenAid Dishwashers
Kitchenaid dishwasher imperial 21
Take the kick panel off under the door and see if the technical spec sheet is there. That lists all the diagnostics that you can run
Nov 20, 2013 | Dishwashers
Need manual for model # for kitchen aid dishwasher KUDS301XBL2
Could your model number be KUDS30IXBL2? KitchenAide has the manuals for most of their appliances on their support site: . Enter the model number or first few numbers and digits and click Go. The direct link to the KUDS30IXBL2 manual in English is: .
I hope this helps.
Nov 16, 2011 | KitchenAid Dishwashers
I need the length, width height dimensions for a KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
if you cannot view this picture then go to kitchenaid site and type model number kuds02frss and select installation guide from the list. Please rate this solution if helpful or else post a comment.
Feb 25, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
I just installed my kitchen aid dishwasher model kudco03fvss and it won't drain. There is standing water in the bottom of the dishwasher. It is a brand new appliance. There is no water going through the...
Hi, my name is Audrey. I am a KitchenAid employee and thought the following link might help address the draining issue you're having with your dishwasher:
If I may be of further assistance to you, you may send me an email through our customer service address,
and type 'Attention: Audrey' in the subject line. Please include your full name and model/serial number, and I would be happy to try to help resolve the situation with your dishwasher.
Oct 25, 2010 | KitchenAid KUDC03FVSS 23 in Builtin...
Blown fuses
You can get the manual for your kitchenaid dishwasher from this link---
Kitchenaid Kuds01dlss Dishwasher Manual
Please post back for any further assistance.
Jul 22, 2010 | KitchenAid 24 in. KUDS01DLSS Built-in...
Want to replace the door on Kitchenaid dishwasher
definitely, check out - they have alot of black options
May 26, 2010 | Maytag MDB7100AWB Dishwasher
Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
Jun 11, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
93 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
