Question about Sharp AR-507 Copier
Need to make tray 2 the default tray
We get a misfeed when we use tray 1. We have to use tray 2 so this won't happen, so I need to know how to make tray 2 the default tray.
I would suggest taking the paper out of tray 1, then it won't feed, and calling for service.
Posted on Mar 04, 2009
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
4200 PRINTER Only wants to print out of tray 1
First you need to verify that tray 2 will print from diagnostics test. Use the arrow keys to scroll down to diagnostics and press arrow key, then use arrows move to paper path test and press arrow again. The default paper path test is tray 2 single copy so just select print paper path test and see what happens. If printer prints from tray 2 then we know tray 2 works and that means you either have a print driver that is forcing printing from tray 1 or your settings on the printer for tray 2 are not correct for what you are printing. Check to make sure the paper size shows correctly and make sure that the switch on the right side of the paper tray towards the back is set for standard and not custom.
Aug 04, 2014 | HP LaserJet 4200 Printer
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
Nov 01, 2013 | Sharp AR-M205 Copier
BYPASS MISFEED, FEED FROM TRAY IS OK
the bypass tray does not have paper sensors, so when you print you need to specify the dimensions of the paper ion the print driver and in the machine system features-tray paper settings..
Jan 20, 2013 | Ricoh Corp Aficio SP 6330N Laser Printer...
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
How to set printing to tray #2? HP Laser Jet printer won?t stay printing on tray 2- They do a lot of printing from this printer in the wire room and for some reason it will not stay printing on tray 2-...
Thanks for the inquiry.
Print a configuration page from the menu to determine what Tray 2 is set to.Pull Tray 2 and make sure the rear paper stop is set to Letterhead. Make sure it snaps into place and is not broken or loose. If it's broken you may have to replace the tray.
On your computer got to the printer driver icon and right click for properties. Make sure tray 2 is set to 8 1/2 x 11. Tray 2 should now be the default tray unless tray 1 (Manual Feed Tray) is open and then it will pull from it first.
Let us know how this works. We need to eliminate these setup issues 1st and more steps can be taken if necessary.
Thanks for contacting FixYa.
Oct 20, 2010 | HP LaserJet P4015N Printer
Misfeed tray 1 z1 z2
may need new feed roller and sep pad is the most common, there can be many reasons for it to misfeed from any tray.
Apr 11, 2010 | Ricoh Aficio 250 Copier
Misfeed when attempting to make a copy - Ricoh FT5535
If you are a technical person you may want to remove the tray from the machine (pull all the way out, tilt upwards, and pull.) to clean the rollers. Once the trays are removed you will see a set of three rollers for each tray. They can be removed and cleaned or cleaned directly on the machine. They may have build up dust on them preventing feed. Reinstall the trays the same way they came out but in reverse steps.
Then:
1. Pull offending tray all the way out and remove paper.
2. Unlock the side guides and make sure they move freely
3. Set about 100 sheets of NEW paper for now and adjust the side guides and the end fence. The end fence must be against the paper (touching) and the side guides must NOT be too tight agains the paper as this will prevent the tray from lifting.
4. Make sure the paper size dial is set to the paper SIZE and ORIENTATION.
5. Close tray and test.
Let us know what happens. In the worst case it could be a Magnetic clutch malfunction
Aug 28, 2009 | Ricoh Office Equipment & Supplies
RiCoh 1075 MisFeeding...
The problem you are having is that developer has fallen down into that area good luck once this has happened the box must be taken apart and blown out...  good luck
Apr 22, 2009 | Ricoh Aficio 450 Copier
Sharp AR-507 Copier Logo
243 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
