Question about Brother MFC-9420CN All-In-One Laser Printer
What is machine error ''00'' for brother mfc 9420
When I enter maintenance mode for brother mfc printer, I get a machine error ''00''. What does this refer to?
jtuminaro
  • 56 Answers
SOURCE: Replace Fuser error will not go away
With in 2 seconds you have to hit Menu,*,2,8,6,4
Continue even though you hear the 3 beeps.
When it does into maint mode press 88
That is parts counter reset
Scroll to the part and hit ok.
Press 99 to exit Maint mode
Posted on Jan 15, 2009
SOURCE: mfc 9420 brother
Same problem, went through the entire printer, removed all parts and it started working. Next day the same message
Posted on Jan 31, 2008
SOURCE: [HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Posted on Oct 22, 2008
SOURCE: brother MFC 9420 says:reinstall tray#1, never goes to ready.
Here is a solution I found posted by Razor. (It turns out my engine controller board is bad.) Good luck with yours.
On your control panel, press "menu/set" "7" then "2". if your page count shows 288,888, you have a bad engine controller board. anything other than that count, most likely is a damaged paper cassette. there is a tab on front left side that is probably worn or broke off.
Posted on Jun 12, 2009
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
SCREEN READS ERROR 71 CALL BROTHER, WHAT IS THE PROBLEM, WHAT NUMBER DO I CALL
This error means that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
If the error comes back, call Brother support, here are contact details:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
Phone: 1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
Monday-Friday, 9:00am to 8:00pm Eastern Time
Jan 12, 2011 | Brother MFC 8500 All-In-One Laser Printer
Error 71 showing on the screen
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial stage of the maintenance mode.
If the error comes back call Brother support, here are the contact details:
901-379-1215 (fax)
Oct 14, 2010 | Brother MFC 9700 All-In-One Laser Printer
Error 71
901-379-1215 (fax)
Sep 15, 2010 | Brother MFC 8500 All-In-One Laser Printer
Error message 71
901-379-1215 (fax)
Feb 14, 2010 | Brother MFC 8440 All-In-One Laser Printer
My Brother MFC-5440CN states machine error 7E. Help!!
error 7e means "no head parameters stored in the eeprom".
1) locate the head data sticker at the front left of the machine. it should have a 12 digits number at the top row and headx..... at the second row. the data is the 12 digits number. if the sticker is missing somehow, there's another one at the head/carriage unit.
2) enter maintenance mode.
3) enter 6 and 8 for property data entry
4) enter 2 5 8 0 within 2 seconds and you're at the data entry state.
5) key in the 12 digits number. use # and 1 to 6 to enter letter a to f.
6) hit the ok button. machine should beeps and display "input accepted". if it say "input error" there's a checksum error, meaning you keyed the number in wrong. it will return you to the data entry state.so just key the number in again (step 5).
7) exit maintenance mode. done.
Nov 21, 2009 | Brother MFC-5440CN All-In-One InkJet...
Machine error 71
901-379-1215 (fax)
Oct 27, 2009 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 210C with error code 4F
This will reset the purge count value. Then restart your printer and it should work just fine !
Jan 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C All-In-One InkJet Printer ERROR 4F
This will reset the purge count value. Then restart you printer.
Machine Error 71, Brother MFC 8440
The problem is in the scanner motor.To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
I hope that this will cancel the error but if not canceled you should call the authorized serviceman to fix your machine.
Sep 26, 2008 | Office Equipment & Supplies
Brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Nov 15, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
658 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
