Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Scond slot memory not recognised by my pc.
The new memory is same size sme type, it can be noticed when using SIW sofware.
  • Ali Yousif Mar 05, 2009
    it is properley inserted
I thing second slort memory is not properley insert in the motherboard
Posted on Mar 04, 2009
  • balraj_priya Mar 04, 2009
    or other u not insert the ram propely
How do you access the memory slots on an acer aspire z3731
Memory Sockets or Slots are the place where memory RAM modules are inserted in the motherboard. The Acer Aspire Z3731 has 4 (4 banks of 1) memory expansion slots. A memory bank is a group of memory expansion sockets, a bank must be completely filled with memory modules of the same size and type in order for the system to recognize and address the memory. i.e. :
2 sockets (2 banks of 1) This indicates that there are 2 memory slots. These are divided into 2 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
3 sockets (3 banks of 1) This indicates that there are 3 memory slots. These are divided into 3 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
4 sockets (2 banks of 2) This indicates that there are 4 memory slots. These are divided into 2 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
8 sockets (4 banks of 2) This indicates that there are 8 memory slots. These are divided into 4 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
12 sockets (3 banks of 4) This indicates that there are 12 memory slots. These are divided into 3 banks, and each bank consists of four memory slots. So you must add memory four pieces at a time (and they must be the same size and type of memory) in order for the system to benefit from the upgrade.
Mar 09, 2012 | Acer Aspire All-in-One Desktop PC - Silver...
Tip
How to Choose Memory (RAM) for Your Computer
You need memory for your computer. But how should you choose the right kind? Whether you're upgrading your computer or building a new one, learn now.
Step 1 If you bought your computer from a manufacturer, use a search engine or go to the manufacturer's site to find the specs on your model. The max RAM found in the specs is likely the max RAM the whole system supports. To find the largest size module the system supports, divide the max supported RAM by the number of slots. Also listed in the specs should be the max speed supported and DDR type (listed as DDR, DDR2, or DDR3). Alternatively, instead of max speed and DDR type, the specs may list something like PC# ####, where the "#" is some number. This is just a different way of representing speed and DDR type, and works equally well in finding the right RAM. If you know the largest supported module, max supported speed, and DDR type, skip to the Tips and Warnings section.
  • Step 2
    If you're building a new computer, follow the above step, except search for motherboard model specs rather than computer model specs. If you don't know the model, look for it printed on the board.
  • Step 3
    If you couldn't find your computer's specs, the info wasn't detailed enough, or you have a custom-built computer, go to http://www.gtopala.com/siw-download.html (also in the resources below) and download the freeware SIW. Install and run it. On the left side, under the "Hardware" section, select "Memory."
  • Step 4
    The "Memory Summary" section on the right side shows the maximum amount of memory that can be installed in the system (listed as "Maximum Capacity"), and below that is the number of memory slots (listed as "Memory Slots"). The "Device Locator" sections tell whether or not memory is installed in that slot. To get the largest size module the motherboard supports, divide the "Maximum Capacity" by "Memory Slots." To get the speed and type, look under the "Device Locator" section, for the listing "Memory Type." Write down the PC#-#### part, where "#" is some number. Also for the listing "Speed," write down the value in parenthesis. For example, in 333 MHz (DDR2 667), write down only the (DDR2 667). You now have the largest supported module, RAM speed, and DDR type. You can use either the PC#-#### or the speed and type when searching for RAM.
  • Step 5
  • In Step 4, you found a supported RAM speed, but it may not be the fastest supported. Just to make sure, look to the left side in SIW. Under the "Hardware" section, select "Motherboard." Using this info, go to the manufacturer's site or do a web search, and see if you can find what maximum RAM speed the motherboard supports.
  • Step 6
    If you're building a new computer and need to buy RAM, look up the specs on your motherboard to find out what kind of memory it supports.
  • Step 7
    The RAM you buy should be no larger than the max supported module size, and should match the type and speed supported by the motherboard.
    Open source site for computer pc error fixing software site is on http://digitalpowering.blogspot.com
  • on Jan 08, 2010 | Computers & Internet
    How do I install an additional RAM card
    The IBM NetVista A22p has 3 memory expansion slots. A memory bank is a group of memory expansion sockets, a bank must be completely filled with memory modules of the same size and type in order for the system to recognize and address the memory. i.e. :
    *2 sockets (2 banks of 1) This indicates that there are 2 memory slots. These are divided into 2 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
    *3 sockets (3 banks of 1) This indicates that there are 3 memory slots. These are divided into 3 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
    *4 sockets (2 banks of 2) This indicates that there are 4 memory slots. These are divided into 2 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
    *8 sockets (4 banks of 2) This indicates that there are 8 memory slots. These are divided into 4 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
    *12 sockets (3 banks of 4) This indicates that there are 12 memory slots. These are divided into 3 banks, and each bank consists of four memory slots. So you must add memory four pieces at a time (and they must be the same size and type of memory) in order for the system to benefit from the upgrade.
    How do I install memory on my IBM NetVista A22p 2292-xxx?
    Memory installation help guides can be found at the following link.
    Memory Installation Guide
    Installing DDR DDR2 DIMMs
    Installing SDRAM DIMMs
    Jan 11, 2011 | IBM NetVista A22p PC Desktop
    Tried installing 4gb memory on to acer aspire 5720z notebook running vista 32bit, they would not be recognised. Have now installed vista business 64 bit & the 2 x 2GB new memory is still not...
    • CPU Section:
    • Microprocessor Full Name:Intel Core 2 Duo processor T5250
    • Microprocessor Manufacturer:Intel
    • Microprocessor Speed (GHz):1.5
    • L2 Cache (KB):2 Mb
    • Frontside Bus (MHz):667
    • Memory:
    • Memory Speed (MHz):667
    • Memory Type:DDR2
    • Memory Size (MB):2048 Mb
    • Max Memory Size:2Gb
    • Hard Disk Drive:
    • Hard Drive Capacity (GB):80 Gb
    • Hard Drive Type:S-ATA
    As you can see from my printout from the web site, this laptop doesn't appear to support more than 2Gb of RAM.
    Sorry.
    Oct 18, 2010 | Acer Aspire 5720 Notebook
    Adding ram
    http://www.crucial.com/uk/systemscanner/?click=true
    download the scanner from that site then run, will tell you everything about your motherboard
    hope it helps
    May 20, 2009 | E-Machines eMachines Refurbished EMA...
    Inspiron 2200 Memory Module not recognised
    Are you sure its the correct speed/type of RAM? According to Google your laptop takes PC2700 DDR RAM, ensure you are using this in both slots to avoid problems. If you have it fully inserted into the slot and nothing happens when you swtich it on then the laptop doesnt like that type of RAM and you'll need to change it.
    May 17, 2009 | Dell Inspiron 2200 Notebook
    RAM compatibility with MK79G motherboard
    Hi, I am assuming that the original piece of memory was a 256mb ddr pc2700/333mhz ?
    i have looked at your board on the product maker website and it supports memory to 2gb of pc2100,pc2700/pc3200 type memory. Be certain however that the new piece added is the same clock speed as the original that you are trying to use with it. You cannot mix clock speeds, either pc will not boot or it will only recognise the compatible piece. Have you tried booting with just the new piece 9 leaving out the older piece)if yes what was the result. Need more help ?? compdoctor2005@btinternet.com
    Jan 03, 2009 | AOpen MK79G-N (91.8B110.101) Motherboard
    Memory
    You didn't give any details, but here is an answer to a common misunderstanding:
    http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=BF4C8393BFC74A83B9EC318630B9CE7D&doclang=en&cs=
    If this isn't your problem, the please post details for us to research
    Jun 14, 2008 | Computers & Internet
    New memory not recognised when installed into spare slot
    "Put it in and reboot"... be sure the aptop is OFF when you add memory! Otherwise, you can damage BOTH memory and laptop! Once memory is installed there is no "trick" to get it recognized. If it is good and meets the BIOS specs, it will be recognized and registered after a cold boot.
    1. Be sure the memory is inserted properly (both clips on the sides are flush with the half-moon tabs between memory and metal clips).
    2. Sometimes on a memory slot that has been empty a long time (and gets a bit corroded) it is a good idea to insert the memory, remove it again and reinsert 5 or 6 times (only) to clean the contacts.
    3. If number 1 and 2 have been done, and you still have this error, then there is a problem with the memory:
    It may be the wrong speed (PC100 instead of PC133, etc)
    It may be too LARGE for the BIOS to use (all laptops have maximum memory per slot specs that must be observed, because the laptop cannot see memory that is greater than its specified capacity.
    In any case, check the manual or the website for your laptop, to get the specifications for memory type AND capacity per slot, and TOTAL memory if you have two slots -or memory soldered on board).
    Feb 10, 2008 | Computers & Internet
    Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
    I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
    http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
    Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
    Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
    21 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
