Question about Karcher Garden
Electric modelm620 karcher does not start
The green light appears when on switch pressed ,power is there, the machine will not start.
  • 14 Answers
The bypass valve is most likley jammed. Remove the cover from the machine, then remove the chemical tank. Unscrew the micro switch cover and manually operate the micro switch. If the motor runs the bypass valve is faulty. Replace the valve along with the stem seals on the valve.
Posted on Mar 06, 2009
I have Xerox 5016 model Photocopier , I am getting Error U4 ,some technican from Xerox advised that it can be solved by pressing some button ..? If anyone can support would be a great help.
Enter into the diagnostic mode.Press 50 then green button,press 20 then green button,press 00 then green button.Switch off the machine & Switch On.
Jan 15, 2011 | Office Equipment & Supplies
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
No power going to the machine
A few things to check, the GFI plug has tripped, the machine has safety switches under cover, could have gotten wet and froze. Take cover off, plug machine in, with a electrical tester start where power enters machine and test all switches till you find bad one.
Sep 28, 2010 | Karcher FactoryReconditioned 1400 PSI 13...
Karcher pressure washer hunts ~ off/on ~ when running. How do I fix?
HI Your machine wil start and stop if you have any external leaks when the machine is running at not pressing the trigger. Please start the machine and not pull the trigger and look form leaks. A common one is around the high pressure hose outlet and also the trigger.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
POWER CRAFT BY Karcher bought Aldi on 31Mar 05.2100Watts 130 bar.
You did winterize the machine? Leaving water in a powerwasher will freeze and damage the pump. It's a common happening, because people don't think of it or are not told by the maker.
Apr 29, 2010 | Karcher K2.26 Electric Power Washer
Australian Karcher 2.91 intermitant start
Under the top cover there is a micro switch that sometimes dislodges
This switch is for auto cut off when you release the trigger
Jul 27, 2009 | Karcher K2.26 Electric Power Washer
Karcher k 2.36 smoking and flashes of light inside the machine.
Hi:
This sounds like a short circuit or motor problem. They are relatively easy to take apart. If you see a burned wire or connector this can be repaired. If not, it is the motor and probably too expensive to repair considering the price of a new one.
Jun 30, 2009 | Karcher K2.26 Electric Power Washer
Karcher pressure washer won't start
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Apr 11, 2009 | Karcher K2.26 Electric Power Washer
Karcher k4.98 switching on and off
The machine has a pressure leak. Check for a cracked controll head or either a leaking outlet elbow. The machine will short cycle if the holding pressure can not be maintained
Feb 19, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
412 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
