Question about Nokia 6233 Cellular Phone
How to lock phone from very start
So that noone can open and see its details
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 96 Answers
Try going to the main menu
Then settings
Then security settings
It should have a password option where you input a password.
Input password
Turn phone off then on.
Input password to get back in to the phone.
Posted on Mar 04, 2009
Karbonn k111 mobile is locked IMEI:910579207893431 IMEIV:1 910579208093437
Ok, it is locked. You need to go to the carrier that carries this phone and have it unlocked. Just went through this with an HTM phone. NoOne would bother with it. the right simm card is needed because they are not all thhe same size nor is the primary data the same.I ended up trashing it. Good Luck with your phone.
Jul 23, 2014 | Cell Phones
Tip
Nokia contact service Tricks
Nokia dct4 contact service hardware or software easy to find<br /> <br /> <br /> NOKIA DCT4 CONTACT SERVICE HARDWARE OR SOFTWARE EASY TO FIND WITH UFS+HWK<br /> <br /> <br /> 1)CONNECT UFS+HWK<br /> 2)SELECT DCT4 TAB<br /> 3)USE INFO BUTTON(SOME TIMES PHONE NOT ENTER LOCAL MODE JUST LONG PRESS POWER BUTTON<br /> 4)CHECK INFO DETAILS<br /> <br /> <br /> <br /> 5)SL DATA CORRUPTED(MEANS SIMLOCK ENABLED)<br /> 6)JUST UNLOCK PHONE<br /> <br /> <br /> <br /> SEE SECOND PICTURE INFO DETAILS 100%DONE.BUT PHONE STILL SHOW CONTACT SERVICE<br /> 7)CONNECT SET<br /> 8)RUN SELF TEST<br /> <br /> <br /> <br /> SEE THIS SELF TEST DEIALS<br /> EAR _CLK_LOOP TEST----------NO SIGNAL<br /> RF CHIP ID TEST---------------FAILED<br /> THIS CONTCAT SERVICE HARDWARE PROBLEM<br /> HARDWARE CHANCE<br /> 60%UPP<br /> 30%UEM<br /> 10%OTHERS LIKE BSI ETC...........<br /> <br /> <br /> <br /> SEE ANOTHER SELF TEST DETAILS<br /> LCD TEST-----------FAILED<br /> RESONS LCD MISSMATCHED<br /> JUST CHANGE DISPLAY NO NEED TO FLASH&UNLOCK ETC.............<br /><br />or alternatively....<br /><br /><br /><br /> <b>SX4: SX4 <span>Smart Card</span>, is a tool or method which is developed by Nokia to<br /> write some data protection for a specific area in EEPROM is useful for<br /> preventing modification of the data.<br /> </b><br /> <br /> When SX4 PROCESS is Required ?<br /> <br /> <b>In the case of a loss (data corrupt) data charging (not charging), data<br /> network (no network). Dll.RF calibration calibration-charging.<br /> So, all these problems caused by mistakes in the process of flashing or after<br /> write RPL or erase process is done in a certain area <br /> </b><br /> <b><br /> <br /> <span>HOW DO I</span> KNOW THAT MY PHONE PROCESS SX4 needs to be done?</b><br /> <br /> <b>When the phone appears CONTACT SERVICE, CONTACT retailers, NOT<br /> charging after flashing, no network, etc. When the SELF TEST is done by<br /> using the box like JAF repair, etc. will be obtained is the result of failed "ST_SECURITY_TEST Failed"<br /> <br /> <b>How do I make a SX4?</b><br /> .</b><br /> <br /> <b>Plug the phone in the repair box (JAF, MTBOX, MXKEY, etc.)<br /> Write pm area with 309 results read from the normal mobile phone or can<br /> also write FULL PM area without 308 (<span>SIMLOCK</span> area). </b><br /> <br /> <br /> <b>What to do sx4 without internet connection?</b><br /> <br /> <br /> sure <span>Certificate</span> damaged area musti made first with the FLASH erase, or<br /> write RPL blank<br /> Reset NPC (when using mxkey)<br /> What is a Certificate Area?<br /> Press info on the box like JAF flasher, etc. and see the results LOG ...<br /> This is an example of the correct Certificate<br /> Default SN type:<br /> <br /> Code:<br /> <br /> IMEI plain: 351862xxxxxxxxxx<br /> IMEI spare to net: 3A 15 68 02 01 23 60 03<br /> IMEI SV to net: 33 15 68 02 01 23 60 03 F6<br /> LOCK STATUS:<br /> Config KEY: 0000000000000000<br /> Provider KEY: 2440700000000000<br /> Provider: AT &T; U.S.A. (3650)<br /> <span>Key Code</span> count: 0, FBUS Code count: 0<br /> Block 1:Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> This is an example Certificate of damaged<br /> <br /> Default SN type:<br /> <br /> Code:<br /> IMEI plain: 123456765321?<br /> LOCK STATUS:<br /> Config KEY: fffffffffffffffffffffff<br /> Provider KEY: fffffffffffffffffffff<br /> Provider: Unknown<br /> Key Code count: 0, FBUS Code count: 0<br /> <br /> Block 1: Lock 1: CLOSED<br /><img src="moz-screenshot-2.png" /><br /><br /><img src="moz-screenshot.png" /><img src="moz-screenshot-1.png" />
on Apr 26, 2011 | Cell Phones
Where can I find a lock cylinder for a 2007 125cc Xtreme ATV
This ignition switch will probably work if your current ignition switch has a 9 prong plugin.
http://www.kidatvs.com/part-detail.php?id=51
Dec 31, 2013 | Motorcycles
Password inquiries
i have been lock out of airg i didnt that till yesterday after noon i didnt want to get lock out i like airg can i get back on there my user name is mamascowgirl password mexico1971 my name is joyce tafolla lopez my phone number is 1-920-570-9827 or 1-920-547-5800 please heil me
May 17, 2012 | airG
Forgot password. Now locked out. Noone seems to
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
Dec 07, 2009 | NorStar Meridian M7310 Phone
Key and latch pull donot work on my truck lock how can i open trunk
You can try to get inside the trunk by removing the passenger seats.From inside there should be the lock mechanism.Usually there is a way to open the trunk from inside(for safety reasons so noone will lock himself in to the trunk).
Jul 16, 2009 | 2001 Mitsubishi Galant
Locking the phone with a code
ENTER THE CODE AND OPEN AND READ UR MESSAGE AND CLOSE UR PHONE AND GO AGIAN IN TO THE MESSAGES AND IF IT ASKS THE CODE GO BACK AND GO TO SETTING AND OPEN LOCKS FLODER AND CLOSE ALL CODE AND TRY IT OK RATE ME
May 23, 2009 | LG Vu CU920 Cellular Phone
Puk code
If your phone is blocked. Take it to your nearest network providers outlet, to get it unblocked.
If your sim card is blocked. You can go to your network providers website,where you can download obtain the puk code that will unblock the sim card.
Nov 04, 2008 | Nokia 6111 Cellular Phone
Unlock phone
hello, from ghana my phone is lock how can i open it please help
Jul 07, 2008 | Sony Ericsson W200i Cellular Phone
Nokia 6233 Cellular Phone Logo
59 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
