Question about Canon imageRUNNER 210S Copier
My system is hanging every 15 mimutes - Canon imageRUNNER 210S Copier
  • Sunil Rathod May 11, 2010
    when printing or in standby
  • 54 Answers
Check the voltage ,ip board ,mother board
Posted on Mar 16, 2009
Circuit breaker kicks off after 3 to 5 mimutes
call in a electrician to check insulation of the circuit
depending on the current requirements of the unit running, check the application of the circuit breaker as it may not be sufficient to run the unit --again an electrician will be able to determine the requirement
for example --if you are running a hot water system through that breaker and it is a 10 amp breaker then the hot water system may be running 10 amps which means that the breaker will overheat after time and switch off
it may require a 15 amp breaker to do the job--as an example
or if you have more than 1 unit using that breaker then the combined current usae is too high for the breaker
Feb 06, 2017 | Electrical Supplies
When i install conquer online or playing game in facebook it may hang in 15 to 30 minutes keep's hanging T_T i cant play my game anymore.. pls solve my problem pls
hello firstly you will need to update windows system followed by installing new updates for flash and java applications
this will see you right goodluck
Mar 26, 2011 | Microsoft Windows Server 2003 Terminal...
Dell inspiron 9300 getting hang or restart after every 15 min
Sounds like your hardrive is starting to fail-backup all files!!!
Apr 12, 2009 | Dell Inspiron 9300 PC Notebook
Printer won't turn on
Try unplug the printer for at least 15 mimutes.
This may reset your printer.
Feb 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Gateway laptop hang issue
Check the Windows Page File to determine whether it's system managed or manually set. The recommended settings is twice the amount of RAM installed in the machine. If set too low the system will hang often, especially when running memory hungry apps.
I would also suggest checking screensaver and power management options in the control panel.
If those don't work, close any unused applications which run at startup (Start, Run, MSCONFIG). Another possible solution could be updating your display driver.
Nov 06, 2008 | Gateway Computers & Internet
Sytem Hangs!
Looks like a bad Memory dimm, try replacing it.
Oct 03, 2007 | Computers & Internet
Canon imageRUNNER 210S Copier Logo
245 people viewed this question
old marine
old marine
