Question about Canopus TwinPact 100 (77010136100) Video Capture
Power switching problem in Canopus twinpack 100
We have Purchase Canopus twinpack 100 on May 2007. I was working fine but suddenly we have face a problem...while working it itself switching off. whenever we start it again after half an hour its again switch off.What is the problem please give us solution....
3 Suggested Answers
bhiga
  • 119 Answers
SOURCE: Canopus ADV c110
It sounds like the DVDs are protected by Macrovision copy-protection. The ADVC units are not designed to bypass Macrovision copy-protection.
Posted on Apr 05, 2008
AldRezaine
  • 995 Answers
SOURCE: For over a year I used this device to send video
Turn your computer operating system back from where it is compatible and can work smoothly.
Posted on Dec 18, 2009
CLASSROOM SUITE 1.4
Fixya will not give out any serial numbers, Activation Codes,
or Key Codes. It is illegal to pirate software
Jul 24, 2012 | Canopus Classroom Suite (77610142-100) for...
Can I use the Canopus Twin Pact 100 to transfer vider from digital video camera to computer? The firewire port on the camera is no longer working, so I need another way to transfer the video to the...
No, it isn't really the right tool for the job.
The Canopus is for converting analog video signals to digital (like capturing the video from your computer monitor as you move the mouse around).
You already have a digital video source (your digital video camera). So this box won't accept that as input.
If your video camera has other output ports, like component video (see below for a picture), then it might work. The Canopus will accept analog RCA for input.
Mar 12, 2008 | Cameras
2007 Pontiac Grand Prix - Tail light troubles - HELP?
Probably a broken ground wire. Check it with a test light. Make sure you have a good ground, and then stick the test light right in the socket to see if there is power. If there is power to the test light, but still none to the bulb, it's a ground wire. If there is no power, its a power wire. Just keep poking the wires, and work your way back until you find some power. Make sure you have the lights on when you're checking. Good luck.
Jul 14, 2009 | 2007 Pontiac Grand Prix GXP Sedan
No analog signals thru ADVC100
Canopus customer support just wrote me back with the bad news: "If all 3 lights are on, then the unit has failed. We no longer
manufacture or repair ADVC 100's (they are almost 7 years old now). You
would need to purchase the newer ADVC 110 as a replacement."
Dec 12, 2008 | Canopus ADVC100 (77610072100) Video...
Vhs pal video not working
Change the DIP switch to PAL, unplug the unit (no power), then plug it back in. You need to power-cycle the unit to after changing DIP switch settings.
Also make sure that your capture application is set to PAL mode, if there is a NTSC/PAL setting.
Nov 22, 2007 | Canopus ADVC-110 A/D Converter...
Canopus Storm Bay
Did you make sure the pins in the s-video cable were not bent?
Oct 17, 2007 | Canopus Storm Bay (770-10071-100) Port...
Canopus ADVC-110
Hi! You must use a firewire in order to receive power - if you're going to use composite cables (red, white, yellow) you will have to purchase an AC adapter.
Oct 09, 2007 | Canopus ADVC-110 A/D Converter...
Canopus ADV c110
Sep 25, 2007 | Canopus ADVC-110 A/D Converter...
Canopus TwinPact 100 (77010136100) Video Capture Logo
144 people viewed this question
Top Canopus Televison & Video Experts
Yoav Shilon
Yoav Shilon
Alun Cox
Josh Whitehead
Josh Whitehead
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
