Question about Sharp AL-1655CS Laser Printer
On my sharp Al1655 cs printer, I get a vertical black line on copies. There's also a black vertical line on the drum. I clean it and sometimes the line goes away--but mostly it comes back. Should I change the cleaner blade?
  • Anonymous Mar 18, 2009
    New Friend:
  • 91 Answers
Yes you must change the cleaner blade
Posted on May 13, 2009
There is a dark vertical line of toner on prints
Common problem. Most likely caused by a bad drum cleaning blade. This is especially true if you run say 10 copies and the last copy out of the machine is worse than the first copy out. Drum cleaning blades are cheap at less than $30.00.
Good Luck and Thank You using Fixya.
Sep 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
Sharp copies AL1655 CS: what does error code (L1-00) mean
check scanner home position sensor & scanner motor
Jan 13, 2010 | Office Equipment & Supplies
Thick black line in all copies on sharp arm 162e
when drum clean blade is weak then strongly can not clean toner,so thick black line in all copies.
Solve: Replace clean blade or service.If your copier drum life is zero,you can change it.
Nov 16, 2009 | Sharp AR-M162 All-In-One Laser Printer
Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Oct 05, 2009 | Brother Multi-Function Center MFC-240C...
Copier says ready to print. when button is
you will require to check several things like ink toners alignments and settings try resetting the wholesystem. top of all there may be some software problem try reinstalling the softwares if it is connected to computer
Jul 21, 2009 | Sharp AL-1655CS Laser Printer
Copy problems
1-if you make a copy on the glass instead of the feeder is it still there?
If no, then clean small 1" glass on copier there is a spot on it. even a pencil or pen dot WILL make a line on all copies. easiest way to find it, line up the paper on the small strip of glass and follow there will be something there ( sometimes it's hard to see since the background is black)
2- the drum has a black toner ring around it replace the drum blade or drum unit
Aug 07, 2008 | Copystar CS-2030 Copier
Sharp Al1655-cs Copy Issue
It could be the feed tires might need to be cleaned or replaced. You should check it our with a copier technician in your area.
Jun 26, 2008 | Sharp AL-1655CS Copier
Black lines running vertically through resulting copies
Clean the scanner glass. a small particle will cause this to happen.
Apr 07, 2008 | Sharp AL-1655CS Laser Printer
i need the driver of my 1655 cs for xp , where i found, no,
Feb 12, 2008 | Sharp AL-1655CS Laser Printer
Minolta Di3510f
probably your drum is dirty and machine needs cleaning.
Feb 04, 2008 | Minolta EP1031/1031F CS/PRO Copier
Sharp AL-1655CS Laser Printer Logo
178 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
