Question about Alesis iO 26 Sound Card
Random reset of unit...
Firewire resets at random, causing the unit to be at full volume every time it resets. Nearly blown my studio monitors several times because of this. it happens quickly and at random,...not enough time to turn the monitors off usually. I have contacted Alesis 4 or 5 times, and never have gotten a response. Re-installed the drivers numerous times, and have done everything imaginable to try and solve this...anyone with the same problem, and possible solution? The drivers for this unit on their website haven't been updated in a year...
This isn't a straight up solution, but it certainly helps...If you have trim (Input Volume) on your monitors turn the IO 26 to full volume and set the monitor inputs to the max that you can stand. That way when it goes back to 100% volume you dont kill your ears or monitors. I am a little worried about the way this effects my head room but its better than losing my hearing!
Posted on May 03, 2011
either you can see if the unit has reset switch, open the case and see if you have blown a fuse, if you dont find a fuse than the unit power supply maybe burned up
Oct 04, 2015 | Focusrite SAFFIRE-PRO-24-B2 Firewire Audio...
What so i do since i forgot my pattern lock how do I unlock my zeki
  1. Make sure your tablet has a full charge
  2. Press and hold the Volume - button and tap the Reset button
    (The reset button is located between the HDMI and USB ports)
  3. Continue holding the Volume - button until the boot screen appears
  4. Release the Volume - button
  5. Use the volume controls to navigate to "Wipe data/Factory reset"
  6. Press the power button to select
  7. Navigate to "Delete all user date"
  8. Press the power button to select
Your table will take several minutes to reboot to a factory default setting.
URL Link:
May 17, 2014 | Shopnbc Zeki 10" 8GB Android 4.0 Ice Cream...
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Monitor intermittent power problems. Horizontal green flickering lines
You have to check the ESR in tha caps in power supply with esr meter.
If you dont have one just replace all capacitors in the power section(there are severals of them)This is the simptom of low esr in the capacitors.
Return the monitor in factory settings.
Jan 28, 2014 | Dell Computers & Internet
I have the htc hd mini, and it freezes all the time and constantly vibrates, even if i have no message and itsfully charged. It turns itself off and takes forever to load when i turn it on. The touch...
Hi you will have to try doing a hard reset or factory reset to fix this issue . PLease follow the below procedure . This will reinstall all the drivers and reload the OS
Doing a hard reset will make you loose your data on the phone .
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone.
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the POWER button briefly and then release it.
  3. When you see a warning message on the screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
Aug 08, 2011 | HTC Touch HD Smartphone
I used my monitors at high volume for approximately 1 hour and they stopped working. One monitor has no volume and the other has very low minimum volume.
You may have blown a fuse in the amplifier. Refer to Appendix A: Service Info in this guide under No Power section, and if the fuse it not blown, try some of the solutions under No Sound. Hope this helps!
Feb 28, 2011 | Mackie Mr5 Active 5" Powered Studio...
Hey I've got a problem where the volume down button randomly "presses itself" and constantly brings up that annoying volume menu. The button isn't "stuck" and it still clicks like all the others, but it...
Do a factory reset of the monitor
by pressing the menu button or auto select
the use the "-" / "+" button to select factory reset and select yes
you can also try this:
Press and hold the menu or autoselect button of the monitor for about 20secs without the VGA or DVI / HDMI cable connected to it from the tower
If the problem continues. Switch off the monitor and remove the power cable and connect it again
Hope it helps u
All the Best !!!
Mar 25, 2010 | HP w19e 19" Monitor
Volume Menu appears randomly; buttons 2-4 don't work reliably
Once you can try providing "reset" option from the menu .... This will solve most of your problems ..
Jul 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Sony Marine Radio
check the wiring is installed correctly make sure you have a good earth & if it is a detachable face make sure the face is on correctly after trying this hold reset button for 15secs
May 16, 2008 | Jeep Radios: Genuine 6 Disc Cd Changer
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Alesis iO 26 Sound Card Logo
292 people viewed this question
Top Alesis Computers & Internet Experts
John Bolton
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Alesis Computer and Internet Expert? Answer questions, earn points and help others
