I could not use bluetooth in my can i use it.
  • 60 Answers
U have to check two basic things .
1-> check the blutooth button is properly on or not
2-> after that searh in two way first search ur system by another bluetooth device.
and then searh another device by ur system.
3-> re install the bluetooth driver and redo the above two steps
Posted on Mar 04, 2009
Asus laptop how do you get no wifi
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on.
When you turn on an Asus laptop's Bluetooth function, you allow cell phones, headsets and any other Bluetooth device to be synced with or found on the laptop.
You can use Bluetooth on a laptop to listen to music on a headset or to sync and transfer files from the computer to the device.
If the Asus laptop has Bluetooth wireless technology preinstalled, you can enable Bluetooth access by changing the settings in the control panel.
Click the "Start" menu and open "Control Panel."
Select "Hardware and Sound" and "Bluetooth Devices."
If the "Bluetooth Devices" option doesn't appear, your laptop does not have Bluetooth capability.
Open "Bluetooth Settings."
Click the "Allow Bluetooth devices to find this computer" checkbox in the "Options" tab.
Click "Apply" to save your settings. Click "OK" to close the window.
Change settings for a Bluetooth enabled device
Jun 10, 2013 | Acer Computers & Internet
How to install bluetooth on my bluetooth lisence is not i really need help..
Toshiba is an electronics company that manufactures various products, ranging from televisions to computers. Some of the older Toshiba laptop models don't have built-in Bluetooth technology. To use Bluetooth on a model like this, you need to purchase a USB Bluetooth dongle and install it on your laptop. Installation and use of these devices is simple.
1.Switch on the laptop, and remove the protective cap from the Bluetooth dongle.
2.Plug the Bluetooth dongle into a free USB port on the laptop.
3.Wait for the laptop to load the necessary drivers. When this process is done, a notification will appear above the system tray (bottom right corner).
4.Right-click on the Bluetooth sign in the system tray to use the dongle. "Send a File" allows you to search for other Bluetooth devices and transfer files to them. "Receive a File" makes the laptop visible to other Bluetooth devices. In the "Options" menu, you can change the Bluetooth name, pair the laptop with other devices and manage various settings.
I hope you find it very helpful. Best regards.
Aug 20, 2011 | Computers & Internet
Bagaimana untuk download bluetooth ke dalam laptop acer saya jenis aspire 4730z
Seperti mana yang saya tahu, aspire 4730z telah dipasang sistem Intergrated Bluetooth 2.0 didalamnya. Awak cuma perlu aktifkan aplikasi bluetooth, Biasanya pada taskbar, terdapat icon bluetooth. Alat untuk awak buat sambungan mesti on bluetooth terlebih dahulu. jika bluetooth pd laptop aktif, aawak perlu mengesan alatan yg aktif, atau anda boleh cuba mengguna hanphone yang ada bluetooth, cuba hantar satu gambar melalui bluetooth. jika hanphone x dpt mengesai laptop awak, maknanya bluetooth pd laptop x aktif..klau jumpa mknanya aktif, cuba hantar, tetapi bila dia berfungsi, awk perlu mengesahkan pd laptop utk menerima data yg dihantar melalui handphone td. awk juga bleh set folder mana yg ditetapkan sebagai folder lalai utk menyimpan setiap data penerimaan..
Aug 10, 2010 | Computers & Internet
Bluetooth is not working...
make sure that all your bluetooth drivers is installed. you can do two way test. first is, have you laptop detect any bluetooth device that you have there e.g cellphone. if laptop was able to detect your cellphone then theres is no problem with your laptop. second is, let your bluetooth cellphone detect your bluetooth laptop. if cellphone was unable to detect your bluetooth laptop then we have issue here on your laptop.
Apr 03, 2010 | ASUS Eee PC 900 Notebook
Acer Travelmate 5620 bluetooth button won't turn on
Do you actually see the Bluetooth device in device manager? Normally if it's not turned on it won't appear in device manager. The next thing I can think of is that if the Bluetooth module was not turned on when you loaded the drivers then they won't work.
And lastly the module may have come lose or unseated from the slot. Are you absolutely 100% sure there's Bluetooth hardware on this laptop? Is this built-in or a USB dongle?
If built-in have you turned it on? Acer uses a slide switch to turn Bluetooth and Wireless LAN on and off.
The first thing you probably need to establish is whether the laptop has a Bluetooth module fitted. Plenty of Acer laptops support Bluetooth in some markets and not in others and actually have slider switches to turn Bluetooth on/off but don't have the Bluetooth module fitted.
Does the unit say that it supports Bluetooth on the sticker attached to the front of the laptop? The models that have Bluetooth typically have this listed on these and will also list it on the packaging that came with the laptop that lists its specs. If it doesn't mention it odds are it's not fitted.
Acer laptops have the Bluetooth buttons, but not always have the Bluetooth Module. Check the bottom white sticker for a Bluetooth symbol under the laptop. If you do not see it, there is no Bluetooth. Also, if you press/move the Bluetooth button, and the light doesn't turn blue, there's no Bluetooth module with your laptop (only the button), so your laptop did not come with Bluetooth.
Also, you can add Bluetooth, but you need to be able to take the laptop apart to a certain extent, such as taking off the cover (top portion), keyboard, and maybe the speakers. The Bluetooth should have a 4pin, 6pin, or 8pin Bluetooth Cable connected to a Bluetooth module. You need to purchase the Bluetooth module, and install it, but you need professional help for that.
In case your laptop won't have a Bluetooth module fitted. The switch doesn't mean anything, it's present on all Acer laptops whether they have Bluetooth fitted or not.
You can buy the module as a spare part from Acer and fitting it is easy however buying a cheap USB Bluetooth dongle will be a cheaper option.
Thank You for contacting
Feb 02, 2010 | Computers & Internet
I want to access bluetooth on my laptop
Click Start - All Programs - TOSHIBA - Bluetooth - Bluetooth Settings.
You may also want to look at the task bar and see if the Bluetooth Icon is there.
Most of the time with the New Toshiba laptops the icon will not appear untils you do the first top step. Once you click on Bluetooth settings your laptop will actually install the Bluetooth Module and make it available for you to pair Bluetooth devices.
Oct 09, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
No bluetooth device
Hello friend. Actually in the Acer Aspire 5720 model (in the main Acer website) it says Bluetooth 2.0+E.D.R (manufacturing option); which means there might be Bluetooth pre-installed in your laptop or not installed at all.
Even if you have a Bluetooth switch on the laptop, it doesnt necessarily mean that there is Bluetooth.
So, I think in this case, there is no Bluetooth device in your laptop.
Or if you are sure that there is Bluetooth module in your laptop then try reinstalling the bluetooth drivers.
But in most cases, Acer laptops (most of them) dont have Bluetooth pre-installed though the laptops have a bluetooth switch.
Hope I am not confusing and this would be helpful.
May 09, 2009 | Acer Aspire 5720-4230 Notebook
Bluetooth drivers
The presario c714 does not come with bluetooth built-in. If you want to use bluetooth with this laptop you can go and buy a usb bluetooth adapter that will allow you to access bluetooth devices on your laptop.
Oct 10, 2008 | Computers & Internet
Bluetooth on HP Pavilion dv4000
i need bluetooth driver for hp pavilion dv 4000
Oct 06, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
