Question about HP Photosmart C3180 All-In-One InkJet Printer
Server-error-service-unavailable on my hp printer
My printer has been working fine until the other day when I tried to print and it was not recognizing my printer. So i clicked the add printer button, and my printer shows up to add but won't. It gives me a "server-error-service-unavailable" reason to why it wont add.
I have a Macbook and my printer model is an HP All-In-One C3100. Does anyone know why this is happening?
  • 3 Answers
See this link, I had the same problem and it fixed mine.
http://slayo.com/hp-printers-mac-os-server-error-service-unavailable-or-error-1282-message-when-adding-a-printer-in-mac-os-x.html
Posted on Apr 06, 2009
Rpc server is unavailable when installing printer
According to the error message, I assume that the spooler service cannot find out the printer on the network.
You may set the startup type of Printer Spooler service to Manual or Delayed Start for a test.
You could go to Customer support- just dial +1(800)243-0051 Toll Free.
Apr 27, 2017 | Office Equipment & Supplies
I have installed hp laserjet 1000 on server 2003.I have shared this printer to my network.I am even able to print from client machines remotely.But one of my client machine shows 'The RPC server is...
RPC service may not be available or started on the client machine.
To start/ enable it go to 'Run Command' and type 'services.msc' , locate REMOTE PROCEDURE CALL (RPC) and start the service.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 07, 2010 | HP LaserJet 1020 Printer
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
May 08, 2009 | Sony Office Equipment & Supplies
The computer displays error "RPC Server is unavailable".
It may be that you have a static value in your registry's field PagedPoolSize, we need to make this "0" (zero). check the steps ->HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
Jan 29, 2009 | Brother MultiFunction Center MFC-440CN...
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at dabesderis06@gmail.com
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
Can Not Print to HP LJ 1020
hook the print server directly to the computer and program it with a static IP address.
than create a new printer port in add printer. Than setup the printer and use the port you just created and it will work fine
Dec 14, 2007 | D-Link DP-300U (DHDP300U) Print Server
Error #57 unable to connect DHCP Svr
Sometimes you can unplug the printer for approximately 20 to 30 minutes to allow the memory to clear and everything should go back to normal. If not try the next steps I have given you. Error 57 is a main motor error. Remove the toner cartridge and see if the error goes away. If not then remove the fuser in the back with the power off. Lower back cover and remove two screws and slide out carefully. Turn the gear on the fuser to see if the rollers turn. If it is binded then the fuser is the issue and needs to be replaced. Check the gears on the right side to make sure nothing has fallen in and stops them from turning. If all ok, then the main motor needs to be replaced.
Aug 17, 2007 | HP Jetdirect 615n Print Server
HP Photosmart C3180 All-In-One InkJet Printer Logo
512 people viewed this question
Seeker5211
Seeker5211
