Question about Cisco (VWIC-2MFT-E1) Modem
3750 send snmp Fan problem
Dear team,
i have 3750 send snmp "Fan problem" when i check localy fan status is OK,
i upgrade the ios but still...problem exist
Regards.
  • 30 Answers
Open up the covers at it may be a fan that is not visible or the rpm of the fan is not enough. Change the fan
Posted on Dec 05, 2009
Suddenly shut down
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Oct 30, 2012 | Dell Vostro 3750 PC Notebook
Cooling fan does not run?
At the main fuse and relay box, check the 30A EGI INJ fuse. If OK, the main relay closes to apply power to the cooling fan relay. Next, check the 30A FAN 1 and FAN 2 fuses.If OK, power is being applied to the fan control module. The PCM processes engine coolant temperature sensor input and sends a signal to the fan control module which, in turn, causes the cooling fan motor to operate. Fan failure could be caused by malfunction of the cooling fan relay, the fan control module, the engine coolant temperature sensor, the cooling fan motor itself, or the PCM
Oct 06, 2012 | 2005 Mazda MPV
Electric fans do not work. Fuses OK Motors also run if hooked up directly.
If the fans work when hooked up directly. this indicates that the fan motors are okay. The next step is to check if the coolant temperature sensor (usually located near the thermostat housing) to see if it sending a signal to the relay when the engine temperature goes above normal. This part is inexpensive and easily replaced; throw one in if you still have the original. A second sensor (or switch) may need to be checked; this is the radiator fan switch. These two usually work as a "team" in managing engine temperatures; one switch tells the computer and the instrument gauge what temperature your engine is operating in, while the other responds by sending a signal to the radiator fan relay to "kick on" the fan.
Lastly, the radiator fan relay itself may have burned out. I usually try to switch out identical relays to determine if this is the problem.
Hope this helps.
Have a Nice Day !!!
Apr 15, 2011 | 1996 Ford Windstar
Error 1203 on a Dell Printer - what is this?
2080 1203 2055...Critical / Failure / Error...2080 1203 2346The Storage Management Service performs alert monitoring and logging. By default, the Storage Management Service starts when the managed system starts up. If you stop the Storage Management Service, then alert monitoring and logging stops. Alert monitoring does the following:
  • Updates the status of the storage object that generated the alert.
  • Propagates the storage object's status to all the related higher objects in the storage hierarchy. For example, the status of a lower-level object will be propagated up to the status displayed on the Health tab for the top-level Storage object.
  • Logs an alert in the Alert log and the operating system (OS) application log.
  • Sends an SNMP trap if the operating system's SNMP service is installed and enabled.
    http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=Error+1203&cat=sup&x=10&y=12
Mar 23, 2011 | Vacuums
I have and Canon iR3570 and when SNMP is disabled the printer goes offline and network printing ends. Enable SNMP and change the default community to something more secure and printer goes offline and...
It's possible that the SNMP Status Enabled box is checked on the print server (Printer/Properties/Ports/Port Settings). When you disabled SNMP or changed the community name on the printer, the server was no longer getting status updates and so flagged it as offline. Make sure the community names match.
Aug 31, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Raditor fan wont come on
First of all, you have to check the status of the fan. Wire it directly to the battery and if it comes on than the problem is with a bad connection or the temperature sending unit. This controls when the fan comes on and goes off
May 10, 2010 | 1998 Cadillac Catera
Printer offline
hi,
try these steps i am sure it will help you..
go to the control panel look for
Printer and Faxes under Control Panel. Look for the printer icon that shows in offline status. Right click 'Properties' and go to the Ports tab folder. Select the Port IP address in question and click on 'Configure Port' button. Click on the check box next to SNMP [SNMP status enabled] to remove the check mark and to disable the option. Click OK on the Configure Port window. Click Close on the properties window,
after that close all the windows and try, this ma help.
Mar 12, 2010 | HP DeskJet D1460 InkJet Printer
We have Phaser 7300's. Our secuty team tell me that we must remove a SNMP Default Community Name vulnerability ny 1) disable or remove snmp services, 2) disable or remove the detected community name of...
1. Open the web management page in your browser. Just put in "http://xxx.xxx.xxx" where the IP address of the printer replaces the x's. 2. Click on "Properties" 3. In the box on the left side, click to open the "Security" folder 4. Click on "Security Settings" 5. Find the line for "SNMP Read" and uncheck the box under "Any User" 6. Find the line for "SNMP Write" and uncheck the box under "Any User" 7. Click on "Save Changes'
That should cover it. Also posted a video showing the steps on youtube. Should be linked from here.
Feb 02, 2010 | Xerox Phaser 7300DN Laser Printer
Hello, I am in Brazil, and my Canon ImageRUNNER C3220, is the problem of off alone, just off the digital display but not print anything when it is so, the technicians who were found not fix the problem,...
If the printer appears as offline in windows, consider disabling SNMP monitoring. Sometimes SNMP falsely tells windows that the printer is offline for events like "toner low, replacement not needed" and "low paper, drawer x"
Go into printers & faxes, right click on your printer and select properties, go to the ports tab, press configure port, un-check SNMP Status enabled.
Mar 03, 2009 | Canon imageRUNNER C3220 Printer
I NEED SOLUTION
Hi, Pls check the small Fuse for the supply of the fan. Or you can send it to us to repair.
May 26, 2007 | Toshiba TLP T50MU Multimedia Projector
Cisco (VWIC-2MFT-E1) Modem Logo
113 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
