Question about PfaFF Creative 7570
Needle hits the bobbin holder and doesn't grab the bobbin thread
It is like the bobbin holder is in the wrong position. The needle keeps hitting the metal part of the holder and won't grab the bobbin thread. It doesn't catch up the thread as normal.
  • teresa_steve Mar 12, 2009
    Thank you for your help.
    Thank you for your input.
    Novelist:
  • 97 Answers
Also note that using a red band Singer needle will cause this exact symptom. The Singer needle is about 1.5 mm too long for use in any other machine. Ensure that you're using a standard needle. (Schmetz and Klasse are good examples.)
Your machine may also be out of time, which would require professional repair.
-R
Posted on Mar 11, 2009
  • 3 Answers
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Posted on Mar 05, 2009
Needle hitting this and breaking. Pulling too ******* thread caught in bobbin case is the cause. How to fix or readjust?
breaking needles from hitting can be from several problems
1-- needle /hook timing is out
2--needle thread tension is too tight pulling needle side ways
thread caught around bobbin holder is top thread too loose
take it in for a service check as the needle /hook timing is complicated to adjust and the problem could be more complicated than suggested
Nov 23, 2016 | Sewing Machines
Simplicity sewing machine SL 9240 was giving to me and when I try to sew the needle keeping hitting the bobbin holderr.
On the right side you have two knobs to make adjustments. The lower knob will move the needle left or right so it won't hit the bobbin holder.
May 31, 2014 | Singer 7442 Mechanical Sewing Machine
Thread breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Aug 13, 2012 | Janome Sewing Machines
Needle hitting bobbin case holder following loud needle breakage.
try these sites they might have a video that would help
youtube
fixsewingmachines.com
Apr 05, 2012 | Sewing Machines
The needle keeps hitting the bobbin holder, it has actually nicked it. I cannot sew, the bobbin thread just jams up in a bundle and the machine jams
Check to make sure the needle is up all the way into the clamp. If the bobbin case now has sharp edges from the impact. polish away the sharpness with an emery board or simular. Once a needle is hit it canot be used again so always use a fresh needle.
Dec 12, 2010 | Euro-Pro 9105 Computerized Sewing Machine
My DB2-B797 suddenly has needle breaking because needle is hitting bobbin. I need help with technical specs and needle positioning. PLEASE
Hi
First thing to check is are you using the correct needle, if it is too long this will hit the bobbin holder.
If the needle is the correct one, for some reason your timing is out or the needle bar has dropped lower than it should be.
I can't explain on here how to re-time as it is complicated.
If the timing is out it is very unusual as the working parts are locked in position.
Take out the thread, remove the needle plate and turn the machine over by hand watching the needle and see if it is actually hitting the bobbin or bobbin holder.
Rob
Jan 02, 2010 | Sewing Machines
My needle keeps hitting the plastic bobbin holder - how can I fix this? Is the bobbin holder inserted wrong?
change the needle and see if it is still hitting because once they hit the case or the feed dog they very often get bent always change needles with different fabrics and types of thread
Dec 12, 2009 | Singer Quantum 7350 Mechanical Sewing...
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Bobbin holder problem. Needle hits bobbin holder and doesn't grab the bobbin thread. It will break the needles if persisted.
Is the needle all the way up in the holder? Have you checked the timing with the bobbin and the needle. Look in your manual for needle timing
Mar 04, 2009 | PfaFF Sewing Machines
Top & bobbin thread will not sew
Most likely the needle is in backwards. Weird I know, I have no idea why but if the needle is in wrong, it either hits the bobbin and breaks or won't grab the thread at all. Good luck.
Jan 06, 2009 | Brother LS-1520 Mechanical Sewing Machine
Sewing Machines Logo
1,279 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
