Question about Philips GoGear SA3125/37 MP3 Player
Can't find where philips device manger is located
My mp3 player turns on, shows main screen and then turns off. it is fully charged and i don't have it on hold. i tried formating it but it won't work. i tried resetting it and that doesn't work. i looked at common problemsand found that the solution was to use the philips device manager but i don't know where to find it
  • nisey76 Mar 31, 2009
    I can't keep my mp3 on, it shws gogear, thn advised to log on to computer and go to device manger, thn turns off. can't find where philips device manger is located
  • 8,596 Answers
It is listed as "Device /Firmware Manager" on this website (warning: this link is only good for the SA3125 - if you have a different model #, don't even think about using it):
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=MP3_PLAYERS_CA&sct=SU00304_SU&grp=PORTABLE_ENTERTAINMENT_GR&session=20090305231122_24.73.84.94&ctn=SA3125/37&mid=Link_Software&hlt=Link_Software
-Tha Mp3 Doctor
Posted on Mar 06, 2009
MP3 player won't turn on.
Well its a software problem so try connecting it to your pc and format it....i think sa kinda virus affected your mp3 player
May 30, 2010 | Philips SA3025/37 Flash MP3 Player
Ive connected my mp3 to my compter and it usaully says charging or fully charged, or do not disconnect, and now it wont even show that or turn on. what should i do?
Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds
Oct 31, 2009 | Philips GoGear Flash MP3 Player
Will not turn on..
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
-Tha Mp3 Doctor
Mar 31, 2009 | Philips GoGear SA3125/37 MP3 Player
Loading Problem - Results in Frozen Gray Screen
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Updated using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 13, 2009 | Philips GOGEAR SA6045 MP3 Player
Gogear mp3
Run the Update tab in the Philips Device Manager - make sure you are connected to the internet before performing the Update.
-Tha Mp3 Doctor
Dec 28, 2008 | Philips GOGEAR SA6045 MP3 Player
Lost cd need device manger
Go to www.usasupport.philips.com and enter in SA2115 instead - it is the same Device Manager
-Tha Mp3 Doctor
Feb 09, 2008 | Philips GoGear SA178 MP3 Player
MP3 keeps deleting everything
Here is something that might help from tha mp3 doctor which i have gotton, thogth I still need the deivce manger:
1) Make sure the usb charger is in the lock position before trying to charge.
2) Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
3) after repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
-Tha Mp3 Doctor
Hope that helps and I just toke this from what I was told.
Jan 25, 2008 | Philips GoGear SA178 MP3 Player
Go gear 30 gb not turning on
In-warranty - call Philips
Out of warranty - call Philips for best repair/replacement prices
Option 2 - consult local yellow pages or Best Buy Geek Squad to see fi they will perform repair
Option 3 - get a new Mp3 Player - the cost of repair usually exceeds cost of gettign a new one.
-Tha Mp3 Doctor
Oct 13, 2007 | Philips GoGear HDD6330 MP3 Player
Disconnecting from my PC
well that's typical from gogear if you've been online looking for clues you see that.Go to http://www.consumer.philips.com download the firmware for your mp3 and the device manger software if you haven't got that as well then reformat with device manager and then upgrade with the new firmware you might also do the soft reset by pushing the "up"button and volume "up" and holding them at the same time .then turn it back on,good luck
Oct 06, 2007 | Philips GoGear HDD6330 MP3 Player
Philips GoGear SA3125/37 MP3 Player Logo
94 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
