Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Please help me to stat this thing I have no manuel
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello mr m, i would be glad to help you if i only knew what kind of trimmer you are trying to start,brand name,model number,would be very helpful. and what is it doing not to start.
  • JERRY ABELL
    HELLO
When I first got my brand new RYOBI LIne Trimmer the *** thing just would not start. I was following the exact guidelines in the maual. First thing is, ensure you get right is fresh fuel correctly mixed accurately with 2-stroke oil. Some machines are more temperamental about the mix. 2. Set choke to COLD, press bulb 8 times (once you see fuel enteing the clear bubble reservoir) 3. Switch on power. It's amazing how often I've pulled the cord with that red button off. Dont think you cant do it to. 4. Pull the cord gently until you feel resistance. Let it gently recoil, then in one non-aggressive move, holding down the unit with your other hand, pull it out at constant speed. Do not yank! If (or rather when) it doesnt start, pull the accelerator trigger a couple of times only, and repeat procedure "4". Don't press bulb again too often or use the trigger too early or you will flood the engine. When I couldnt get my strimmer to start at all, I got this advice from an online engineer, it fired up *first pull*.
If it's not starting after a winter rest, did you store it empty of fuel because that is always wise. Discard old petrol mix and start with new. Hope that has helped.
Posted on Mar 18, 2009
I just got a new Diesel Audio NS-9915, I dont have manuel so I can not set clock or adjust sound I need help! Please
go down to auto zone or advanced auto napa ect!!!
order a haynes repair manuel
they cover every thing from (codes) to electrical
motor / transmission / rear ends / drive train
i find its very informational
hope this helps you
good luck
bob
May 08, 2011 | Diesel Audio Car Audio & Video
I HAVE A GOODMAN HEAT PUMP, MODEL AR30-1. I switched off the heat pump at the stat and the elements seem to be running heating up the unit... Also what is the brown wire coming from the wiring harness for...
The brown wire on a Goodman is tipically for the emergency heat option on your heat pump. First thing I would check is making sure it is wited correctly. Verify your stat is heat pump capable. Many of the cheaper stats only work for ac or just a heat pump. Anything beyond that would be a more serious electrical problem and should be looked at by someone with the proper training and tools.
Feb 11, 2011 | Goodman Heating & Cooling
Furnace keeps going off and on every 20 seconds
Hello, First of all I need to know a little more information. What kind of furnace do you have? Gas or electric? One thing you may do to eliminate the thermostat is to take off the front cover of the stat and jumper the W and R terminals to determine if it is the stat or the furnace. If you do this on the stat and the unit heats up and stays running then you have a bad thermostat. If this does not make the furnace stay on then you have another problem. ( be sure to turn off all power to the furnace before you start working on anything) Please supply more information for further help. J
Jan 27, 2011 | Heating & Cooling
Do you go up or down with the numbers to get coolness in temp?? Have misplaced my manuel.
Hi, with the stat set to cool, you will go down with the arrows to make it cooler, and up for warmer. On heat, go up with arrow for warmer and down for cooler.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
PS Please don't forget to rate me and please be kind as I know you will. I will be here if you need anymore help.
Aug 05, 2010 | Heating & Cooling
The car is running hot and we cant figure out what the problem is, we have changed the therm stat, water pump, radiator can you please help or is there so kind of cadillac manuel for the 99 car its a...
turn the engine on, feel any water flow on either radiator hose, you can feel it, but abiously after it warms up thats when the thermostat opens, does it run rought at all??? lag of power, does it. check your fan clutch/electric fan. did you actually overheated the engine at all? the rason why is cause this engines have the habit of messing the headgaskets and over heat. that if worse gets to worse. let me know
Aug 01, 2010 | 1999 Cadillac DeVille
Need full version of micrsoft office 2007 with mega stat
no such beast as free naything from microsoft
Go to OpenOffice.org and download the clone that reads writes MS filoes and even looks like it. ITS FREE for life so why pay MS a fortune when you can have the same thing for nil.
Please rate my help++++Thanks for using FIXYA
Jun 11, 2010 | Microsoft Office Professional 2007 Full...
FDB949GFB2 Frigidare Dishwasher
don't know this appliance but as a guide:
take top off and dryer manifold goes across the top of the machine. there are various stats mounted on the manifold. one or more may be resettable stats ie have a litle button in the middle. press the button to reset. if you have access to a multimeter, check continuity thro the stats as wee and check continuity thro the heater itself
Sep 05, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
EOB6630X ELECTROLUX ELECTRIC BUILT IN OVEN
which stat is it - overheat stat or temperature stat?
May 13, 2008 | Electrolux EOB6636X Ultrafan Electric...
An "Invalid Dimension Error" on my TI-83 (not plus)-- Please help!
I'm having the same problem and I tried turning off one of these stat plots but turns out I don't know how to do it, or how to tell if I did or not. Help please?
Thanks
Oct 12, 2007 | Texas Instruments TI-83 Plus Calculator
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
420 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
