Question about PfaFF Sewing Machines
Bobbin holder problem. Needle hits bobbin holder and doesn't grab the bobbin thread. It will break the needles if persisted.
  • teresa_steve Mar 04, 2009
    Thank you, I only have an instruction manual. I don't know if a needle timing problem is something I could do or I need professional help.
Is the needle all the way up in the holder? Have you checked the timing with the bobbin and the needle. Look in your manual for needle timing
Posted on Mar 04, 2009
Needle hitting this and breaking. Pulling too ******* thread caught in bobbin case is the cause. How to fix or readjust?
breaking needles from hitting can be from several problems
1-- needle /hook timing is out
2--needle thread tension is too tight pulling needle side ways
thread caught around bobbin holder is top thread too loose
take it in for a service check as the needle /hook timing is complicated to adjust and the problem could be more complicated than suggested
Nov 23, 2016 | Sewing Machines
Buttonhole
The needle thread breaks
1. The needle thread is not threaded properly
2. The needle thread tension is too tight
3.the needle is bent or blunt
4. The needle is incorrectly inserted into the needle holder
5. The needle thread and the bobbin thread are not set under the presser foot when starting sewing
6. The threads were not drawn to the rear after sewing
7. The thread is either too heavy or too fine for the needle
Bobbin thread breaks
1. The bobbin thread is not threaded properly in the bobbin holder
2. Lint has collected in the bobbin holder
3. The bobbin is damaged and doesn't turn smoothly
Mar 13, 2015 | Sewing Machines
Why does the thread break once you start sewing?
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Jul 11, 2014 | Husqvarna Sewing Machines
What to do when the thread keeps breaking
Jul 10, 2014 | Singer Sewing Machines
Thread keeps breaking
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
Thread breaking
Aug 13, 2012 | Janome Sewing Machines
My DB2-B797 suddenly has needle breaking because needle is hitting bobbin. I need help with technical specs and needle positioning. PLEASE
Hi
First thing to check is are you using the correct needle, if it is too long this will hit the bobbin holder.
If the needle is the correct one, for some reason your timing is out or the needle bar has dropped lower than it should be.
I can't explain on here how to re-time as it is complicated.
If the timing is out it is very unusual as the working parts are locked in position.
Take out the thread, remove the needle plate and turn the machine over by hand watching the needle and see if it is actually hitting the bobbin or bobbin holder.
Rob
Jan 02, 2010 | Sewing Machines
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Top & bobbin thread will not sew
Most likely the needle is in backwards. Weird I know, I have no idea why but if the needle is in wrong, it either hits the bobbin and breaks or won't grab the thread at all. Good luck.
Jan 06, 2009 | Brother LS-1520 Mechanical Sewing Machine
Sewing Machines Logo
416 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
