Question about Brother HL-2040 Laser Printer
HOW DO I REMOVE SPEND TONER IN HL 2070 N and insert new toner
Open front cover, pull out drum/toner unit, press lever to release toner, put in new one,and replace.......ta-daaa
Posted on Mar 10, 2009
How to change the toner?
Open the front door, remove old toner+drum, remove the toner from drum unit, put new toner in drum unit, insert unit into printer.
Apr 15, 2011 | Brother HL-2040 Laser Printer
I have a HL 2070 Brother printer That that toner light will no go off, I replace with a new toner and after that did not keep working, I tried to reset the toner opening the front door, also holding the go...
Hi there!
You can remove the drum and toner, remove toner from the drum unit then gently rock the toner from side to side for about six times to distribute the toner inside, then on the drum unit slide the green tab on the upper left hand from left to rigth for about six times and then put it back to the home position. Reinstall the toner back to the drum unit and then put the drum and toner back to the printer. closed the front cover. the toner light should turn off,
Hope this helps.
Mar 28, 2011 | Brother HL 5250DN Laser Printer
How to remove the cartridge on Brother HP1440 printer
Hi seevram,
Follow the procedure below to remove and replace toner cartridges for your Brother HP1440 printer:
1. First, open the Front Cover of the printer.
2. Remove the Toner Cartridge(s) that has run out of toner. Pull the Toner Cartridge out slightly with one hand, then hold the Toner Cartridge with both hands and pull it out of the printer.
After rocking each new Toner Cartridge 3 to 4 times from side to side, remove the tape labeled 'REMOVE' and the orange protective cover from the new Toner Cartridge.
4. Then,
insert the new Toner Cartridge(s) by positioning it in the correct guide(s). Slide it gently into the printer.
  • Do not try to lock or push it in; it should rest loosely in the guide rails.
  • Each color cartridge is individually keyed to prevent improper installation. Match each cartridge color label to the corresponding label on the printer.
5. Finally, close the Front Cover.
Also, I have included here a link where you can download a service manual for your Brother HP1440. Kindly click here.
Hope it helps.
Thank you for using Fixya.
Feb 16, 2011 | Brother HL 1440 Laser Printer
HL 2140 printer need ink cartridge installation instructions
This is a laser jet printer there is no ink, it uses toner. Purchase a toner cartridge and open the lid, remove old cartridge and insert new one. The part number for the cartridge is TN360. Good luck. here is a place that sells them for $50.00 You might be able to find it cheaper if you look around.
Jan 17, 2011 | Brother Office Equipment & Supplies
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
Repeated paper jams from the brother hl2070n after remove toner
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore.
Oleg Andrukh IT Specialist 215 364 3774
Apr 26, 2009 | Brother HL-2070N Laser Printer
HL 2070 Printer Toner light will not go off
Ok, I’m going to try and explain this without pictures:
Take out the toner and look at it. One end has 2 silver screws in it. As you are looking at the toner from the front (transfer roller pointing at you) the screws are to the right. Remove these screws and so remove the face-plate. There is a white gear-wheel (without cogs/teeth) that looks a little like a Y. This simply lifts off; behind it is also a metal spring. Remove this gear and the spring. Now replace the face-plate and the 2 screws without the gear and the spring. That’s it. Put the toner back in and print until no longer possible as the light will not show when it really is empty.
Hope this helps.
Jul 27, 2008 | Brother HL 5250DN Laser Printer
I have a brother HL-2070 laser printer and have just inserted a new toner cartridge. When I turn on the lase printer it is coming up orange light toner & will not print. Its as if its not recognising...
Have you tried shutting down and restarting after the cartridge was in?
Also at Brother there is a new driver download for your model, and other info.
May 01, 2008 | Brother HL-2040 Laser Printer
HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Mar 28, 2008 | Brother HL-2070N Laser Printer
Brother HL-2040 Laser Printer Logo
James Cagle
James Cagle
Jim Keysor
