Aiwa nsx-9000 is eating my tapes
Nsx-9000 is eating my cassett tapes; also does not pick up and play cd's makes a clicking sound when I try to play them
  • frankiepenam Mar 05, 2009
    thanks for the advise but I can't find an other aiwa audio shelf system that has dual cassette tape decks with auto reverse system.
    Problem Solver:
  • 6 Answers
Well 1st unplug it then you can start by qtip cleaning, blowing internal maintenance service. But for the most part regardless of use or age whenever there is gears, bands moving parts which in time get worn, Now this is were keeping clean extends life, So time to shop for a new 1 because repairs and part availablity exceeds the value,of your problem
Posted on Mar 04, 2009
Cds skip on first songs tape deck eats tape aiwa 3300
Nov 30, 2012 | Aiwa NSX-A777 Shelf System
Make the FixYa experience better for everyone by voting.
As you are probably aware, Aiwa is a defunct company. However, several of their manuals can be found by CLICKING HERE
Good luck,
May 04, 2012 | Aiwa Audio Players & Recorders
I have a nsx-9000 cassette deck will not play.
Make a note of how the belt fits, then remove it and measure the diameter. Then buy a replacement, belts do go bad from time to time, so a new one might cure the problem. Put the diameter size (to the nearest mm result, IE: 50 or 55mm, not 52mm! Into google and "cassette belt" and you should find one for the job.
Feb 26, 2010 | Aiwa Audio Players & Recorders
I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Feb 23, 2010 | Aiwa Audio Players & Recorders
Click Aiwa Support to download required user manual for CX-NMT520 (NSX-MT520) that has all info about this sound system.
Dec 18, 2009 | Cameras
When playing a tape there is a clicking noise, its very fast (think running past a chain link fence and holding a stick against it) the tape will play, and will pop out fine, but the clicking noise is...
Something is inside the cassette well. Or one of the reels is slipping. Reach in and manually rotate each reel hub to see if you can feel any reason for a click.
Nov 07, 2009 | Aiwa NSX-AJ20 CD Shelf System
Have Aiwa NSX-V9090 Stereo with jammed cassette. I removed the cassette; however the system still thinks it's in there? When I power up the system it tries to play the tape the stops. I am not able to load...
Check with a small torch, to ensure that there is no tape broken arround the pinch roller or head, if there was no tape broken away, between the pinch roller and the cassette head there is a white cassette bar, this may have become bent.
Aug 08, 2009 | Aiwa HS-TX426 Personal Cassette Player
Cassette tape stuck and door won't open.
Ruan, A temporary fix, is to leave the right side panel off, position your latex gloved hand into the back, of the drive, turn softly, with one finger, the drive wheel, and the unit will unlock. You can now remove the tape cassette. Make sure the cassette tape is very, tight prior to installing it..
To complete a repair, takes a while for full explanation. Regards fmauka...
Jan 06, 2008 | Aiwa NSX-A505 CD Shelf System
Double cassette deck inoperative
im sorry but your deck is broken but give this a try get a tooth brush and clean the inside of the tape deck make sure u clean everything
Dec 31, 2007 | Aiwa NSX-AJ70 Shelf System
Tape deck does nothing when play is pressed
Maybe a problem of no power to motor. I own 2 identical Aiwa units, both have tape deck problems. This brand is prone to them They also have nasty habit of tape cassette doors jamming.
1st off you never said how old the unit is. Awia have huge amount of models. Mine are the NX series that came out in black plastic. Most of the others are silver/grey. Honestly, unless you pop side screws and lift the cover off to eyeball anything loose. and none is? And if out of warrenty, the value of fix, mat exceed value of unit.
Sorry, but I see many of these,  of 4-5 yr old units Aiwa brand,
get the heave ho!
The most stupid thing about this is: for units size, has the best sound of any other brand it's size.. Brilliant for hooking to ones TV sets, for  surround sound!
What I did was get an older getto blaster  that plays tapes to play my tapes on. some of these units are around and in good order, dirt cheap. And most electronic equipment problems cost at least $35  just to have a quick look at your unit.. cost of repair on top?  I brought my 1st one new @ well over a grond. 3 yrs later, 2ns one, exactly the same $15.00 in a charity shop. The  laser unit was dusty. All go in half an hr. Perhaps if it is an older model , look for another mate to it,   It all comes down to costs.
Which is better option... you are the one who has to made the choice. Good luck. Jamz
Oct 25, 2007 | Aiwa NSX-AJ20 CD Shelf System
253 people viewed this question
