Question about Watches
Need a replacement back for a ladies titan raga watch, in gold small rectangular style watch
Noggin
  • 944 Answers
SOURCE: VicencE Gold Ldies Watch
Try this link - nobody seems to claim to specialise in Vicence but I am sure you can find one to suit. Most jewellers deal with most brands. http://www.yell.com/ucs/UcsSearchAction.do?scrambleSeed=33030598&keywords=watch+repair+vicence&companyName=&location=LONDON&search=SEARCH&searchType=advance Hope this helps :)
Posted on Mar 26, 2007
dmbgo
  • 58 Answers
SOURCE: Need screw for watch Style#NY-4285
Hi, you should be able to get one from a watchmaker
Posted on Jun 22, 2009
SOURCE: need to find style name for my cartier watch!!!
i both a watch its unlisted by kenneth cole, i like to lear to set the alarm
Posted on Sep 08, 2009
escapement
  • 2334 Answers
SOURCE: how can you get into a sovereign ladies watch to
You have to pull stem out of watch movement completely and then remove watch glass. Sovereign watch cases are monoblock, so, the only way to get into it is to remove the glass. Rate me, plz.
Posted on Feb 10, 2010
Testimonial: "thanks, the watch seems to be made to look like the back is separate, does the stem just pull out. it only seems to come out about 3mm.thanks"
mcdevito75
  • 1970 Answers
SOURCE: I have a citizen quartz gold ladies watch with a
mcdevito75 here, Look for a small watch repair shop in your area they may be able to add a link or tow to the band.
Posted on Aug 28, 2010
I need help finding how old a womens Seiko watch it has two set of numbers can u help me
Farrah, Contact Seiko or try Google search your watch Seiko # and see what comes up then try the second #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ladies Watches
Seiko Ladies Gold Dress Watch Maroon Dial Gold Mesh Bracelet Ca 1970s
Seiko ladies watch Gold with maroon face Google Search
Aug 08, 2016 | Seiko Watches
Need appraisal on my grandmothers old bulova watch, serial # 1518119. It has links as its bracelet and is attached to the watch on its side with clips
Without more information, such as a picture of the watch or more information about the case, it is difficult to provide a value for this item. In general, vintage fancy ladies watches (the kind that are approximately the diameter of a U.S. nickel or smaller) are not very collectible. As recently as a few years ago, these were bought and sold in bulk for only a few dollars each. In nice cosmetic condition and running properly, a Bulova ladies fancy dress watch in a steel or gold-plated case might retail for between $15-50 at an antique mall. They might sell for somewhat more at a jewelry store that stands behind the accuracy of the movement, but because the inventory of these watches is so large and demand is fairly small, prices for these watches remain much more modest than similar age men's mechanical wristwatches.
Some valuation exceptions do apply. Certain brands of watches, such as Rolex, IWC, Blancpain, and other premium brands, are worth much more than common brands like Bulova. Ladies watches with sweep second hands, as opposed to fancy watches that just have hour and minute hands, are more desirable and are also worth somewhat more than average. Also, watches in solid gold, platinum, or silver cases--or watches with diamond chips or ornate cases--are also worth at least their "melt value" as scrap metal or have an independent value as fine jewelry. All precious metal cases must be labeled; if they are not labeled on the outside of the back cover, they should have be marked on the inside of the back cover (you'll need to carefully take the movement out of its form-fitted case to see this). Be aware that "14k RGP" or "rolled gold plate" on the case means it is not solid gold. Similarly, cases that are "warranted" for 10, 15, 20, or even 30 years are also gold-plate, not solid gold.
Today, with the increase in gold prices, many people have been buying these watches to melt down the gold-plated or gold cases for their gold value, throwing out the watch movements and watch bands. This may have a long-term impact of raising the value of these watches in the long term, as this is decreasing the supply of available watches of this type (it's also frustrating to watch collectors to see the watch movements discarded, as these are valuable sources of replacement parts that are no longer made). However, tens of thousands (more likely hundreds of thousands) of these watches exist in the United States alone, so there is little likelihood that these will become scarce in the immediate future.
May 09, 2011 | Bulova Watches
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
I need a battery for a lady's Pulsar,small watch. I have access to several styles,but none of them are small enough. I've tried #373, #377,#363/364.All seem too big.Any help appreciated. Lee
What happened to the battery that was in the watch? It should have the right information to get a replacement.
Short of that, I'll need the model number of the watch (not just the Brand) to research it)
Oct 08, 2010 | Seiko Watches
Crystal on ladies watch cracked..where can I find the crystal for this ladies Vicence ?
mcdevito75 here, Best Bet, look for a small watch repair shop in your area, and even then It"ll most likely have to be ordered.
Jul 01, 2010 | Vicence Rectangular Watch
I have lost the back of a gold ladies geneve watch. can I get a replacement back? Gold case, white dial with black clear numbers , gold brick link type bracelet. 9ct.Quartz model.
Best bet here is to go to a dealer that carries that brand and seeing if they can order you a new caseback.
Or, you can look for the same model online or EBAY that is broken or in disrepair, then just scrap it for the caseback. (It is not always possible to find one, but i recommend trying as this is the least expensive way to obtain small parts).
Oct 17, 2009 | Watches
Need to find style name for my cartier watch!!!
Aug 13, 2008 | Watches
Feb 12, 2007 | Vicence Rectangular Watch
Watches Logo
118 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
