How can i fix this problem.
SOURCE: RCA HD52W59, Convergence is out, not even on set
you can fix it for 24.00. You can get the ITC222 & ITC222A convergence option missing repair kit at the following link which contains the parts and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
SOURCE: convergence option missing from set up menu rca
Usually if something is missing from the main menu or no longer listed in the menu, is because the Main EEPROM has crashed. To get the right replacement, you will need to have the Chassis number, (CTCXXX), at the time of order. You can order it from Encompass Elect. at 1800-638-3328.
I hope this helps
Skyassoc
SOURCE: My RCA HD52W59 HDTV has a convergence problem. It
On your Deflection Board it is the bottom left hand side board has FBT flyback transfomer on it Blowed Fuse FL231 it will be on right hand side of FBT there is 3 of them in a roll small brown rectrangler looking caps but they are fuses ir will be the one in the Middle Call PartStore.com 1-866-925-7278
SOURCE: RCA hd52w59 out. Powerlight flashed 3x with chirp
Sounds like the Horizontal output transistor needs replacement.
Testimonial: "Appreciate the recommendations provided. Even though the TV didn't respond, the help was just what I needed."
SOURCE: rca hd52w59 the main menu keeps popping up
What you need to try is to remove back cover with set UNPLUGGED.
With back off look at the three large black lenses--there is a small circuit board in the middle of the three---there will be at least three plugs on that board and ONE GOES TO THE FRONT KEYBOARD.
The idea here is to unplug the plug going to the front keyboard---the set will still turn on with the remote.
If the set works normally this way the Menu button on the front of the set is bad---they are called micro switches.
Try this as the only other possible reason is most likely unfixable.
SD TECH Steve
