Question about Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White
Problem overflow valve
The water level in the tank rises too much and flows over into the intake there fore the water trickles continuosly into the bowl
  • 4 Answers
Firstly open the top of the Cistern(Where water is held)There are two most common Cistern internals ie;Ball-O-Stop(Ball on a arm connecting to valve). This one is easy, you just bend the arm downwards in the centre so that the ball shuts the valve at a lower level; The other type has a shaft(plastic) with a thread on it, connecting it to a "small bowl" that lifts up as water enters the cistern. To adjust the water level in cistern you have to turn the thread(Shaft) lowering the "small bowl" wich will shut the inlet to the cistern at a lower level. Hope this helps
Posted on Mar 22, 2009
After my toilet fill valve shuts off, water continues sipping into tank slowly. This causes water continuously overflow through overflow tube.
check that the fill valve was installed correctly
adjust the float level so that when full the cistern water level is around 1/2" below the over flow pipe end
what you have now is that the inlet water is not being shut off correctly and the water is still coming in and flowing out of the overflow
Mar 20, 2017 | Washing Machines
Raising water level in toilet bowl Niagara Stealth
the water level in the pan is set by the exit pipe level and if it is raised it will only flow out again to that pipe level
if you are ferefing to the cistern water level
remove the top and adjust the float level or level control unit
Sep 10, 2016 | Niagara Stealth Ultra High-Efficiency -...
Can I adjust the water level in the bowl?
Hi Jeff:
Two things affect the water level in the bowl:
1) - The maximum height is determined by the siphon. To see if that is where you are, slowly pour water into the bowl. If the level stays the same, that's the maximum height. If it increases, you may be able to "tweak" the trickle tube. (next step)
2) - "Trickle tube" - My term as that's a good description. Lift the lid off the storage tank. If you look into it you will see a vertical tube, open at the top. A small tube should be clipped on to it so that when you flush it, water from the small tube flows into the big tube. That will be "trickling" into the bowl to fill it to the top of the siphon level. Sometimes this small tube can be installed so that it misses the big tube so the bowl does not get filled to the maximum.
- Hope this helps.
Cheers..
Dec 04, 2015 | Home
When i turn on the washer it won't start& water keeps flowing into washing machine. does the water flows or not suppose to flow into the washing machine from the inlet valve?
water into a washing machine is controlled by a tube in the side of the bowl up to a pressure switch
as the water level rises in the bowl, pressure in the switch is built up until it overcomes the setting that you have made for a water level on the wash size selection switch
at this point it turns off the inlet solenoid switch and starts the wash cycle
If the water solenoid is burnt out then water will continue to come in and over flow the bowl but it should be washing as well
If the water is not stopping then check for a disconnected hose to the switch or ma hose full of water
failing all that get a washing machine mechanic in
Apr 18, 2015 | Maytag Neptune MAH5500B Front Load Washer
The saniflow is trickling and filling up bowl then flushes itself
You need to adjust the float. Or, you can buy the complete inexpensive float valve assembly at Lowes or Home Depot and can install it in less than 5 minutes. Turn off the water supply, drain the tank, sop up the remaining water in the tank or put a pan under the tank opening for the next step, remove the valve assembly and float and install the new valve assembly with the float included. Turn on the water supply and set the water level adjustment valve to about 1/4 inch below the stand pipe overflow drain. This is done by the float assembly. Turn on the water supply. This completes the change-out.
Oct 12, 2014 | saniflo"" turboflush toilet"
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
Ariston Problems
If you have to turn the water off at the mains it will probably be that the float valve rubber is worn out allowing water to keep flowing into the tank. Remove the float and the valve that it is attached to and replace the seat in the valve
Apr 27, 2013 | Cars & Trucks
Toilet water tank keeps fillng above the water line. No leak anywhere.
Sounds like the float is not attached...it should be attached to the flapper ....it may need adjusting
Oct 16, 2012 | Fluidmaster Toilet Tank Complete Repair...
Water running into the bowl after flush and refil
IT SEEMS TO ME THAT THE BALL-**** (FLOAT SWITCH) IN THE CISTERN IS SET TOO HIGH UP. THERE ARE MANY DIFFERENT MODELS BUT ALL SHOULD BE EASILY ADJUSTED. HAVE A LOOK INSIDE THE CISTERN AND ADJUST THE FLOAT SO THAT THE WATER STOPS AT A LOWER LEVEL. IF THE WATER IS CONTINUOSLY FLOWING INTO THE CISTERN WHEN FULL YOU MIGHT NEED A NEW INLET WASHER
Feb 08, 2012 | Saniflo & Saniplus& Macerator Pump
Fluid level keeps rising n the tank, eventually leaking through the flush handle. How do you lower the flush level to stop?
First of all, the overflow tube should be lower than the flush handle hole. If not, any malfunction will cause this.
Secondly, every fill valve is different. On some, you have to lower the ball float.
or, some have a screw at the top of the fill valve to adjust water level.
or some you have to rotate the body of the valve to set the height.
Also, if the level rises slowly, there may be debris in the valve or the valve should be replaced.
Gary
Jul 31, 2011 | Home
Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White Logo
2,632 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Caroma Home Expert? Answer questions, earn points and help others
