I put in a disc, pressed play told could not run this disc. When I tried to open the tray it would not open
    Genius:
  • 1,550 Answers
Try pressing repeatedly the eject button while you turn on the unit. If this doesnot work
then it is a mechanically problem in your player .
You need to manually open to take out the dvd .
The rubber thread which should be connected to the motor inside the DVD player might have moved from its place.
You need to place the rubber thread to proper place.
Also if the belt is slipping, the mech never gets the "drawer closed" signal, and the disk will not spin.
Posted on Mar 04, 2009
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Jan 20, 2016 | Sony CDP-CE375 5-Disc CD Changer
Yes when I try to open the Xbox 360 disc tray the power button in the center flashes as if the disc tray is opening, but doesnt open. it flashes even when i havnt pressed a button for it to open the d
Try turning off the 360 then turning the xbox on its side, turn the machine back on holding the eject button and the power button together for about 30 secs then the machine should function normally
Jun 19, 2014 | Microsoft Xbox 360 Console
Console will not read and play any game
Try every disc you have. If the others all work then it could we that disc along. If what i told you doesn't work then get back in touch with them.
Mar 16, 2010 | Microsoft Xbox 360 Console
Xbox will will not play any games or DVD's.
try putting the game disc into your game console and close the lid with your hand without pressing the close lid button. hold the disc tray with your hand and turn off the game console. Turn on the game console. If problem still persists try cleaning the xbox with a blower or a vaccum. Pm me if problem still continues. Thank you .
Aug 07, 2009 | Microsoft Xbox 360 Console
XBox 360 disc tray open
i have the same problem i called xbox and they said that it needs a new disk drive and it would be 100.00 so if you want it fixed youll nedd to call 18004myxbox and they will give you all the info on were to send it or for 100.00 more you can buy a new one like i did
Apr 28, 2009 | Microsoft Xbox 360 Arcade
Yamaha S661 Player wont play multi region
This one is for S530, S540, S550, S557, S560, S600, S657. It's worth a try. Tell me if it works.
  1. Open the disc tray
  2. Press 9, 9, 9, 9, 0
  3. Press ENTER
  4. Close the disc tray
Apr 13, 2009 | Yamaha DVD-S661 HDMI DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Tray won't open
What your husband is doing appears to be the right approach. Looks like the CD was not inserted properly and must've gone out of its seating and preveting the door from opening. Just pusing the CD back to position should take care of it.
Jan 02, 2007 | NAD T562 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
