Question about Toys
Converting Little Tikes Roller Blades
I was given used Little Tikes roller blades for my child. I want to convert the 3 wheeled roller skate to the 3 wheel inline skate. I am not sure if I have all the needed parts. Is there a manual to this?
Thanks!
Roger
  • pab011503 Apr 01, 2009
    I have the opposite problem. Our skates are in the inline position and I want to convert them to the trainer skates. I have directions in the box, but they only explain how to replace the wheels and brakes, not how to convert them.
My nephew has these skates and I just converted them from the training position to the inline position. The skates come with a bag of extra parts that you need to make the conversion. Basically you need the same bolt that is used for the first wheel and the middle wheel since the back two wheels are mounted on a long bolt that doesn't work for just one wheel. If you didn't get these spare parts then you're probably out of luck. If you're converting to the inline position you might be able to just use the front and rear positions but the plastic frame may not be strong enough. Good luck!
Posted on May 10, 2009
What is ice skate? And where can I get the ice skates for girls?
ice skating is like roller skating only on ice
ice skates are available from most sports shops
Oct 14, 2016 | Sport & Outdoor - Others
My daughter broke the part of her skates that holds the break can I replace this and if so from where and how
try phoning your local roller skating rink they may have a service to fix skates or will be able to advise where there roller derby skaters get their skates repaired locally.
Aug 23, 2015 | Cycling
Buying roller skate parts can be expensive. How can I prolong the life of my skate wheels?
The inside of the wheels is usually the first to go - you should rotate your wheels so that the worn out edge is on the outside, this will wear the wheels out evenly and they will last longer.
Jan 17, 2013 | Sport & Outdoor - Others
The wheels on my roller skates are vibrating and sluggish when I skate, what could cause this?
. It seems as though your line bearings inside the wheel need to be changed. To do this you should: Use an Allen wrench to remove the axle from the front wheel. Pull out the front wheel. Remove the old bearings from either side of the wheel. They should pop right off if you use a bolt or something similar. Place new bearings on either side of the wheel. If necessary, use a flat surface for extra leverage. Place the wheel in the wheel frame. Use the Allen wrench to replace the axle. If your spacer is aluminium, tighten the axle bolts as far as they will go. If your spacer is plastic, tighten the bolts as far as they will go, then loosen them slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If it wobbles, tighten the axle. Repeat the steps for the remaining wheels.
. I am great at roller blading, does this mean that I will be good at ice-skating?
They are pretty similar however ice is very slippery so there is an obvious difference.
How can I maintain my figure skating blades and boots?
Keeping your figure skating boots and figure skating blades dry is the key to their longevity. Figure skating blades should never be stored in plastic blade guards!! Always wipe off any moisture from figure skating boots and blades. You can use teri-cloth blade covers, Zookers, or Blade Blankies to store figure skating blades. It's typically a good idea to occasionally take your figure skates out of your skating bag to let them "air out". Also, never leave figures skates in your car during warm weather seasons. Most figure skates are heat moldable and leaving them in the car can misshape and ruin your figure skates.
Answer from: http://figureskates.discountskatewear.com/t-Faq-figure.aspx
How to change a wheel on a roller-skate?
To change a wheel on your roller skate please do the following:
Unscrew and remove the axle bolts from the front wheel with an Allen wrench. Pull the front wheel out of the wheel frame. Remove the bearings and spacer from the wheel. All components should slip out together. Place the spacer and bearings into the new wheel. Place the new wheel on the wheel frame. Replace the axle and tighten it using the Allen wrench. If your spacer is aluminum, tighten the axle as far as it will go. If your spacer is plastic, tighten the axle almost as far as it will go, then loosen it slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If the wheel wobbles, tighten the axle. Repeat the previous steps for the remaining wheels.
Jan 13, 2013 | Sport & Outdoor - Others
One of my bower roller skates has a wobbly when can I fix this or will I need to buy a set of wheels?
I am feeding the wood but the rollers seem to be lower than the blade consequently the front roller is getting in the way and not allowing the wood to be in contact with the spinning blades.
go to the back of the planer and remove the cover. loosen the bolts holding the blade and let it out a fraction. it should have springs to push it out a little. make sure both blades are out the same abount. it is not hard to do and will be quick.
Aug 31, 2010 | Tools & Hardware - Others
CHAMPION PAPER SHREDDER
My champion shredder had too many papers go thru because I didn't see the enclosure in one of the flyers. the shredder has now stopped. I have tried to pull the paper out but I reverse the wheel and now the paper is stuck behind the the wheel where I can reach. The motor is now ona humming sound. Are there screws on either end that I can remove the top? Please give advise n what to do. This is not and old shredder.
Oct 20, 2008 | Office Equipment & Supplies
Toys Logo
1,205 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
