Question about Lasko 5610 Baseboard Heater
Cannot get the heating element to turn off properly on Lasko 5620
I have a Lasko 5620 baseboard heater that came in the box from Lowe's without an instruction manual. I apperantly set a temperature, but the unit does not turn off when it has reached the temperature I set. I have to just turn off the unit when it gets the room too hot.
  • prichardwirt Mar 05, 2009
    This is definitely a stand-alone unit with its own digitial conrol panel
    Thanks for the reply...
  • 462 Answers
From whatI have seen on base board heaters if I recall correctly, the thermostat may be sepperate. Usually thermostats on these have a round knob. 1 line goes to this and the other side of the thermostat goes to 1 end of th element and the othe line attaches to the other side of the element. Its possible you have the element wired in directky if it came without a thermostat and without instructions it may till be connected directly. You should have an L1 and L2 connection and hope there is a wire diagram on the cover.
THE reason these basebord heaters used to come without a thermostat is because they are (OR WERE)set up to add on additional heaters comming right on down the wall. At the last one you could tie in and get a correct rated thermostat installed in the center of the series.
Return to LOWES and ask them to remove the instructions and copy them for you from another like model. Or have them contact the manufacturer and request they fax a copy of instructions with a diagram. Also ask if the heater comes with a thermostat. It may stoill be sepperate in another kit.
Posted on Mar 04, 2009
Cant get the heat to go past 71
Check your thermostat. Maybe it's cutting off ahead of the set temperature. May need recalibration or replacement.
Nov 12, 2012 | Lasko 5620 Electric Baseboard Heater
The heater is causing interference with my Satellite TV signal reception. When I turn on the heater my signal begins ti digitize then it goes out. what can I do to prevent this I have the baseboard heater...
sounds like the heater might have a bad heating element or the transformer inside the unit is shorting out. first thing that I would check is to remove the wire plate and check for any burned out wires. ( this unit could be a serious fire hazard ) --- you could always have a electrician come out and check the unit for voltage problems or for about the same price you could go down to your local Hardware/appliance store and just buy a new unit and replace it,, they install very easy and it only takes about 30 minutes to remove and replace the unit --- try and get a unit with the same messurments so you will not have to paint the wall area around the new unit.
now one more quick test to trouble shoot the unit --- try and run power to your satellite system via a extention cord and a different outlet from inside the house. there is a chance that the sat system and the baseboard heater are sharing the same power source and when the heater kicks on ( with its problem ) it is causing a issue with the sat system.
again,,, check out and solve this problem soon as it could lead to a electrical fire.
Jan 30, 2011 | Lasko 5620 Electric Baseboard Heater
Orange light came on
The orange light is just an indicator light to show you that the heater is working...there is nothing wrong and nothing to worry about...
Jan 04, 2011 | Lasko 5620 Electric Baseboard Heater
Heater thermostat kiks off aftre about 5 min.
First check the wiring to make sure that there are no loose connections... also check the thermostat to make sure that the heat is not affesting it directly and that the sensing part of the thermostat is away from the elemnt enough to sense the ait temperature and not the element heat....
If all of that checks out then try to change the t-stat... it is bad...
Dec 15, 2010 | Lasko 5620 Electric Baseboard Heater
Our Lasko 5620 has a digital control, but we can't set the temperature. It says at 76 degrees, no matter what we do. Hitting the control buttons does not work.
Based from your comments, it seems that you have a
defective digital control. Have a check up for this item.
It may need to be replaced. Hope this will help you.
Jan 10, 2010 | Lasko 5610 Baseboard Heater
Need manuall for model 5620 electric baseboard heater
If google and manufacturer website are of no help then ask a search agency like - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
Jan 04, 2010 | Lasko Under Desk Space-Saving Area Heater...
Yellow caution light
I also have the model 5620. with the yellow caution light on. After taking the unit completely apart I found 2 thermal fuses on the bottom of the unit(appox. size of a nickel). They are located under 'U" shaped brackets which are below the medal heating element. The thermal fuses do not reset. you could test them with a drip or two of souder or wire on the top - if you ran the heater this way it would be a safety problem as the fuse would be overridden. I am throwning mine away.
Mar 16, 2008 | Heating & Cooling
Lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Feb 12, 2008 | Heating & Cooling
Lasko 5610 red caution light, no power
the caution light is telling you something is wrong. most wired baseboard heaters have a hi limit cutout that may be bad.  it is connected into the heater circuit as a safety device.  you could jump out this element to test this theory.  if the element is shorted, certainly it would blow a fuse or circuit breaker.  if the element is open it won't heat at all.  you need to take it apart and use a test meter to troubleshoot it.
Jan 02, 2007 | Lasko 5610 Baseboard Heater
Lasko 5610 Baseboard Heater Logo
555 people viewed this question
Top Lasko Heating & Cooling Experts
Steve Oakes
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
