Question about HP Photosmart C7180 All-In-One InkJet Printer
Hi, I would like to print on Transparency paper, but it will not allow me, what am I doing incorrect please . does it go into the photo tray or paper Tray ? Regards Ellen
Hi
First of all, are you working with a laser printer or inkjet? if it is laser make sure that you have the correct transparency, IT MUST BE HEAT RESISTANT! if it is not,u'll end up buying a new fuser unit. then...
1. Put the transparency in your MP tray
2. When selecting "print" click on properties and select your MP tray as your source,
3. Select Transparency for you media type.
after doing this you will be able to print your transparencies.
I hope it helps
Kind regards
Yolande
Posted on Mar 04, 2009
Can't print on transparency film
In order to print on transparency film from a HP8600 all you have to do is load the paper rough side down with the white border going into the tray toward the back of the printer so that you can not see it when you look into the paper tray. The HP 8600 will auto-adjust for the film, that is why you do not have the option to select transparency like you did in the HP 8500
Dec 22, 2012 | HP Officejet Pro 8600 e-All-in-One -...
Can i print onto Transparency film from my Canon MG 6150 as there is no setting for transparencies, what paper setting would i use
Try the setting for glossy photo media. You want a minimum of ink. Also use the transparency media intended for ink jet AND observe the correct side to be printed on.
Jun 08, 2011 | Canon MG6150 Printer
I have a lasser printer CANON LBP-5200 can I to print on photografic paper?, how many gr.?
Are you saying photographic paper or do you mean photoprint paper?
Yes, laser printer print just fine on photoprint paper. I use 20 lb or 22 lb bond. 18lb is a little light and is not usually photoprint.
If you mean overhead transparency, you have to try it. On some units the overhead transparency will melt a bit and wrinkle. You may need to try different makes of transparency. Make sure it says OK for laser printers!
Apr 17, 2010 | Office Equipment & Supplies
Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Mar 24, 2009 | Xerox Phaser 7700DN Laser Printer
Paper settings
When you change the settings do you hot then 'OK' button to see that the astix is next to it ? When changing settings make sure that you see that astrix next to your changes if not you will return to it's original setting. I alreaded assumed you knew how to access the menu's Make sure you set these setting by"OK" some printers like "Xerox" will make you hit the "Select" key
Mar 04, 2009 | Lexmark C522n Laser Printer
Epson artisan 800 wont print to a transparency
OK so i tricked my 810 into printing on a transparency. NOT that I recommend doing this ... but .... I took four pieces of clear tape and taped the top (where it goes into the printer) and on each side about three inches from the top.
Then I put it in the tray with the transparency on the bottom of the paper -- since it brings it up thru the printer and flips it over, it prints right onto the transparency !!!
It didn't like it the first time, since I just folded over the tape on the end that gets sucked into the printer first. Hence the added stabilizers on each side.
Feb 15, 2009 | Office Equipment & Supplies
Color transparencies are dark & poor color
Nice printer.. Hope this will give hints. Considering transparency papers, please try another batch of or a piece of transparency paper. Try to adjust also the graphics preferences (dark to light) aside from transparency paper selection. Have a nice day.
Best regards,
Rosener Guyano
Feb 17, 2008 | Epson ACULASER CX11NF All-In-One Printer
Canon MP800 printer
says there a paper jam in the out going slot.I have tried everything . HELP please
Oct 28, 2007 | Canon PIXMA MP830 All-In-One InkJet...
HP Photosmart C7180 All-In-One InkJet Printer Logo
272 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
