Question about 3Com 3C16750B / / HUB 8-PT 10/100BTX DUAL SPEED (3C16750BUSED)
Ethernet error I have two PC working in a network together.The hub is connected via LAN between one pc and the other.Already checked both PC and ethernet error still.I wonder if the cause can be located on the hub,perhaps the port i am using now has a malfunction.Changing port on the hub can be the solution ?
  • 271 Answers
Try changing ports on the HUB.
Posted on Mar 04, 2009
I cant connect laptop with ethernet cable
I assume the LAN adapter driver is installed and is working properly.
The LAN cable maybe faulty.
If the LAN cable is colored red then it is a crossover LAN cable and this is a special LAN cable for connecting two computers together without a network hub or router.
Try a another LAN cable..
May 13, 2012 | ASUS Computers & Internet
How to connect 2 pc together
You can network two PC together without a LAN hub using a 10baseT crossover LAN cable. I recommend this method as you can add a LAN hub to expand your home network over other methods..
Check out this WEB site for this and other methods so you can decide which is best method for you.
http://compnetworking.about.com/od/homenetworking/a/connecttwocomp.htm
Mar 28, 2012 | Computers & Internet
Getting low or no connectivity error when trying to connect laptop and other devices to 5-port DLINK switch. Lan line going to switch is confirmed working as i'm able to plug the laptop and other devices...
please change the cable which is connecting your laptop to D-Link DES 1005 Ethernet Switch.
This error appears when you have either a bad cable or bad switch or NIC card on Laptop.
As you have Laptop and other devices and getting the same error , so i suspect issue with the cable.
Please use a new Straight LAN cable.
Oct 31, 2010 | D-Link DES 1005 Ethernet Switch
There is no connection to the other pc
3 ethernet cables 1 ADSL modem and 1 hub is needed to network computers together.
1. connect telephone cable to modem and switch it on. 2. one end of an ethernet cable is connected to the modem . consider this master ethernet cable. connect the other end of this to the master hub port. 3.now connect pc and any hub port with another ethernet cable(ec) say ec1 4. likewise ec2 to another pc .
try this out to get net in both pc's
Jan 12, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Hello need help in config a wsg-404 ap and then connecting another ap via ethernet cable from the wsg-404 to the other ap cant seem to get it working right
If you are trying to network two computers together without a hub, then you must use a crossover LAN cable, not the standard LAN cable.
Aug 09, 2009 | Computers & Internet
Networking 2 computers
Yes you can make a simple Network between 2 PCs ....but ....you need what is called a "crossover ethernet cable" or "xover". A standard RJ45 ethernet cable WILL NOT work.
You also need to make sure both Pcs are in the same Workgroup and have unique computer names.... as is standard in Networking.
Dec 31, 2008 | HP Pavillion ZV6000 Notebook
Connect two computers together
Technically, yes. Both computers should have an Ethernet port (LAN), a crossover networking cable, peer to peer networking using static IP add, and Internet Connection Sharing on the PC with the Wireless Internet Connection. If by chance the PC with the Internet access is already using its Ethernet port, a second NIC could be installed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 28, 2008 | Computers & Internet
Connection problem between modem router and hub
Sounds like you may need what is called a "Crossover Cable' connecting your router to your hub, or if either device has an uplink port, use it on one device to connect to normal port on other device. Here are instructions for making your own cables: http://www.lanshack.com/make-cat5E.aspx
Dec 08, 2006 | Kingston EtheRx Networking Switch
Computers & Internet Logo
81 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
