Question about Panasonic Televison & Video
Vertical blue line appears on the television
A thin vertical blue line appears on my high definition television screen in the same location on the right side of the screen during the playback of blu ray DVDs using the HDMI cable and also when the Panasonic blu ray player is connected using the component video connectors. The blue line is not always solid, sometimes part of it appears and disappears, but the blue line is in the same location on the screen. Any recommendations for repair? Thank you.
  • sschrier Mar 04, 2009
    Thanks for the suggestion but I've done this and it doesn't make a difference. The line still appears. The blue line doesn't appear on the TV screen when using other high definition sources, only the Panasonic DMP-BD10AK blu-ray player. It may be best to take this in to Best Buy for repair rather than opening the top and adjusting the circuit board myself.
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
What is your tv model ?
Remove the connections and connect all the device once again to check its not connection fault .
Posted on Mar 04, 2009
  • SAM ANDERSON Mar 04, 2009
    Is your unit under warranty ?
    It is better to leave to technican to do the board adjustment .
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Blue Lines streaking in from left side of 70 inch Sony HD TV
okay my friend your tv vertical circuit is begining to get faulty you could be having some bad caps or the vertical ic is defected have a tech check your tv for repairs.if you are not a tech you cannot repair the set by your self.good luck.
Jun 25, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Thin vertical lines
Those lines are called retrace lines. They are there all the time on projection TVs but you should be able to see them. When you do see them, that's an indication that the kine screen settings are too high or the supply voltage to the kine driver circuit is low or missing. There is a small, black control unit located behind the speaker grill assy in the front of the TV that has 2 sets of 3 controls. A red, blue, and green focus and screen controls. See if you can make the lines dissappear by turning the screen controls counterclockwise. If you can't you'll need to have service come out to troubleshoot it.
michtech
Feb 02, 2009 | RCA D52W19 52" Rear Projection Television
Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
Sep 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 21, 2007 | NEC LCD
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Televison & Video Logo
42 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
